Block guards + sleeving
Old Feb 23, 2006 | 07:56 AM
f22abuilder's Avatar
Default Block guards + sleeving
Since the the f22a is an iron block and stronger then most I was wondering if anyone knew which would be more bang for the buck trying to boost up in the 15-20 range. Getting a block guard or sleeving. My future application would leave me at a mx boost of 25. SHould i go for the sleaves or stick with the block guard. Can you fit more then one block guard in ????
Sleaves
BLock guard good enough
Rods and piston already in. HEad work already done.
Old Feb 23, 2006 | 11:12 AM
The Weather Man's Avatar
well. Lets see.
If you have pistons and rods in - i'm assuming you would be able to boost atleast 15psi that way. If you want to get up to 25 - i would really suggest you to sleeve.
Also, it all depends on what size turbo you're using. I'm assuming you're going to use a pretty decent sized turbo.
Old Feb 23, 2006 | 11:24 AM
Shakes's Avatar
space cadet
Default Re: (TheKINGPin)
Cost, speed and reliability; You can only have two.
Old Feb 23, 2006 | 11:32 AM
The Birdman's Avatar
Default Re: (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22abuilder &raquo;</TD></TR><TR><TD CLASS="quote"> sleaves....Sleaves</TD></TR></TABLE>
I say sleaves... haha
wtsapexipowerfc
May 7, 2011 11:25 PM
blackccoupe
Oct 14, 2010 10:28 PM
killacam661
Nov 26, 2007 12:35 PM
Rod.
Sep 12, 2003 10:51 PM
B18CHatch
Oct 18, 2001 03:06 PM
