Using MTF as Engine Oil
Old Mar 1, 2006 | 01:42 PM
K-Spec's Avatar
Default Using MTF as Engine Oil
I've heard people putting engine oil (10w-30) into their trannies and using it in place of tranny fluid without having any problems. What if you use MTF as engine oil? Would it hurt the engine? (not that I plan on doing this, just curious)
Old Mar 1, 2006 | 01:44 PM
hu's Avatar
hu
Default Re: Using MTF as Engine Oil (khalal538)
Haven't heard of anybody doing that... nor do I want to be the 1st to try!
Old Mar 1, 2006 | 01:50 PM
petern101's Avatar
Default Re: Using MTF as Engine Oil (hu)
i wouldn't either, mtf usually has some additives
not a good idea
Old Mar 1, 2006 | 01:56 PM
92vteclude's Avatar
mtf prolly has friction modifiers... not good for rod and main bearings... not to mention cam surfaces..
Old Mar 1, 2006 | 03:45 PM
vinuneuro's Avatar
Some people run a little atf through their engines for a 5-10min at idle as a flush to clean. Using it long-term would be bad for the bearings.
Old Mar 1, 2006 | 05:14 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Using MTF as Engine Oil (vinuneuro)
LOL!
1.) Why would you want to?
2.) It would break down REALLY fast!
3.) There are some cars that use ATF/MTF fluid as power steering fluid.
I would NEVER use ATF/MTF as an oil...It WOULDNT work!
(I work at Vavlvoline)
Old Mar 1, 2006 | 06:10 PM
94Vtecluder's Avatar
Default Re: Using MTF as Engine Oil (AnthonyG2003)
Yes people do use motor oil in your tranny. No it won't break your tranny although I imagine it would take more wear and tare when compared to MTF. Why even do this tho?
Old Mar 1, 2006 | 07:05 PM
EOE's Avatar
EOE
Default Re: Using MTF as Engine Oil (94Vtecluder)
Ive been using Mobil synthetic 10W30 in my tranny for almost 2 yrs now. Helps out allot during cold winter hard shifting issue.
Old Mar 1, 2006 | 07:23 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Using MTF as Engine Oil (EOE)
You can use engine oil in a tranny and it works fine. But as far as using MTF/ATF in a engine as a substitute for engine oil...I wouldnt recommend!
Old Mar 1, 2006 | 08:06 PM
bb6prelude97's Avatar
im not sure for all but i know for some cars honda recommends 10w30 in the manual trans. if by mtf you mean gear lube......why would you put that in your engine??? its like 80/90w
knock knock knock knock knock
Old Mar 1, 2006 | 11:49 PM
shdriver99's Avatar
Actually I'm ASE Certified and work at Pepsi, went to automotive tech school for a year. The MTF/ATF have about 90-95 percent detergents in them and people do run it through their engine all the time. It won't hurt your bearings and no more than ten minutes at an idle and your engine is pretty much ready to be drained and refilled with your particular choice of engine oil. IT WONT HURT YOUR ENGINE!
Old Mar 2, 2006 | 12:51 AM
K-Spec's Avatar
Default Re: Using MTF as Engine Oil (shdriver99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shdriver99 &raquo;</TD></TR><TR><TD CLASS="quote">Actually I'm ASE Certified and work at Pepsi, went to automotive tech school for a year. The MTF/ATF have about 90-95 percent detergents in them and people do run it through their engine all the time. It won't hurt your bearings and no more than ten minutes at an idle and your engine is pretty much ready to be drained and refilled with your particular choice of engine oil. IT WONT HURT YOUR ENGINE!</TD></TR></TABLE>
so what are you saying? the MTF works as a cleaning additive for our engines?
Old Mar 2, 2006 | 05:31 AM
EOE's Avatar
EOE
REALLY.... I think ill stick to seafome tho. lol
Old Mar 2, 2006 | 06:03 AM
Honda318dx's Avatar
MTL = Honda's Manual Transmission Lube = w30 oil
ATF = Automatic Transmission fluid = Very high in detergent
Putting MTL in the oil will just make the oil less viscous, which isn't good for startup
Putting ATF = Just scares me, if the motor has been running great, leave it alone..
Old Mar 2, 2006 | 08:11 AM
Default Re: Using MTF as Engine Oil (Honda318dx)
Even that doesn't make much sense. If you using it to clean your engine then why not just buy a OSC SPECIFICALLY DESIGNED to clean your oil system. Peeps is wierd these days.
Old Mar 2, 2006 | 09:45 AM
prelude1897's Avatar
Default Re: Using MTF as Engine Oil (bb6prelude97)
I've used motor oil in my tranny before. It didn't make much of a difference
Old Mar 2, 2006 | 11:54 AM
prelittlelude's Avatar
Default Re: Using MTF as Engine Oil (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">I've used motor oil in my tranny before. It didn't make much of a difference</TD></TR></TABLE>
yeah i have heard of motor oil in the tranny, but i wouldn't put it in my motor, im runing 10w30 in my chevy 5speed tranny right now works fine.
Old Mar 2, 2006 | 05:04 PM
h22chilton's Avatar
* B A N N E D *
i was in a desperate attempt to get my car across 4 states once (FL 2 KY) while i was throwing some fuel code that i couldn't fix, so i poured a bottle of atf in the tank that was 1/4 full tryed to clean the fuel system, the car made it! with 60-70 psi compression drop in every cylinder!
Old Mar 2, 2006 | 07:06 PM
EOE's Avatar
EOE
Default Re: (h22chilton)
UMMMM
Old Mar 3, 2006 | 10:01 PM
i'm ase certified also...!?
you can run 1 qt of atf with your oil before an oil change to take advantage of the detergents <U>DO NOT FILL YOUR ENGINE WITH TRANSMISSION FLUID</U>
change your oil every 3,000 miles and you won't have to worry about de-sludging.
Old Mar 4, 2006 | 12:22 AM
K-Spec's Avatar
so i guess ATF= a cleaning additive for the engine...and MTF= a broken engine
Lucas_pln
Apr 17, 2007 06:06 AM
mugenpowered
Apr 29, 2006 05:40 PM
K-Spec
Sep 27, 2005 09:15 AM
JDM Like Whoa
May 28, 2004 11:47 AM
Mario.
Mar 24, 2004 10:06 AM
