Code 61 Exhaust problem... Advice?
Old Feb 23, 2006 | 06:21 PM
m.c.'s Avatar
Default Code 61 Exhaust problem... Advice?
My engine check light came on yesterday and the code was 61 for Primary heated Oxygen Circuit slow response. I was wondering if anyone else had experiance with this part malfunctioning and if anyone knew whether it is best to just replace the part or could there be a wiring or other problem.
Thank you
ps. I am assuming I can drive with the problem without causing further damage
Old Feb 23, 2006 | 07:13 PM
v4lu3s's Avatar
RTFM
usually that means get a new o2 sensor, unless it is intermittent.
Old Feb 23, 2006 | 07:15 PM
piotrush's Avatar
Default Re: (v4lu3s)
I got the same code. Got a new o2 sensor end it went away. I went to http://www.sparkplugs.com and got a denso sensor.
Old Feb 24, 2006 | 07:28 AM
m.c.'s Avatar
Default Re: (piotrush)
thank you
and am i looking at the right part?
http://www.sparkplugs.com/more...=1825
Modified by m.c. at 11:50 AM 2/24/2006
Old Feb 24, 2006 | 09:02 AM
piotrush's Avatar
Default Re: (m.c.)
yep, same part # I got
deftones0817
30
Sep 2, 2006 05:21 PM
Gen5lude
Mar 29, 2006 12:10 PM
frostee
Nov 19, 2004 04:21 PM
inzecure1
Mar 18, 2004 10:43 PM
