could this be shift linkage problem?
Old Feb 26, 2006 | 01:46 PM
sohc prelude's Avatar
Default could this be shift linkage problem?
my car usualy will not let you down shift into 2nd gear the only way u can down shift into 2nd is if u push it up towaeds frist and them come down.. it will noit go into 2nd comeing form any other direction? dose this mean smoethings wrong with my shift linkage.. also it dosnt not grid or anything.. it feels like a lock.. (like form 5th to reverse) any body know what could be up?
Old Feb 26, 2006 | 07:26 PM
LudemanDan's Avatar
Default Re: could this be shift linkage problem? (sohc prelude)
That's kind of strange. Have you tried using the engine to coax it into 2nd from neutral? As in, are you sure it's not RPM or speed related? Because that sounds like a problem a lot of people have with 1st gear. My suggestion is change the tranny fluid right now (with Honda MTF) and see if things improve over the next few trips.
Dan
B16aCRXSi
20
Nov 7, 2008 11:49 AM
92hatchboi
Oct 22, 2007 06:13 PM
Boostedb20EH2
May 4, 2007 01:51 PM
JDM4DRACCORD
May 23, 2005 09:03 AM
