prelude h22 swap problem
Old Feb 28, 2006 | 04:28 PM
darockstar's Avatar
Default prelude h22 swap problem
im going 2 put a jdm h22 on a us h22 harness is there anything i have to worry about as far as the plug for the coil on the us harness?? the jdm dizzy has a internal coil??? also i dont have the h22 ecu harness ill be using the h23 ecu harness on the p13 is there any thing i have 2 worry about....as far as coverting it??? please help....thanks........im in florida n have lots of h23 engine parts.....everything must go.......need money....low ballers welcome....itsoundsgood2me@hotmail.com
Old Feb 28, 2006 | 04:37 PM
SteveoBA8's Avatar
Default Re: prelude h22 swap problem (darockstar)
Use usdm H22 engine harness(connects to chassis harness with connectors on passenger side engine bay.)
The ecu will plug right in no problem( as long as its obd1=92-95)
Use your Usdm H23/H22's distributor and external coil
If you use the jdm h22's internal coil dizzy you need to do some rewiring
As for your parts /\ FOR SALE ONLY section up top.
Old Mar 2, 2006 | 01:37 PM
darockstar's Avatar
Default Re: prelude h22 swap problem (SteveoBA8)
so the h23 dizzy and coil fits a jdm h22 with a us h22 harness????
Old Mar 2, 2006 | 02:07 PM
Cottonwoodz's Avatar
Yes
Old Mar 2, 2006 | 06:11 PM
jdmlude_dude's Avatar
Default Re: prelude h22 swap problem (Cottonwoodz)
if you have an obd1 h22 harness and an h23 dizzy, then are you set to go. Just slap that ***** in and go!
Old Mar 3, 2006 | 08:28 AM
darockstar's Avatar
Default Re: prelude h22 swap problem (jdmlude_dude)
thanks for the help guys......hope the h22 rips!!!!!!
Old Mar 3, 2006 | 08:32 AM
darockstar's Avatar
one more question my lude is a h23...i want to upgrade the brakes....can i get a kit for the vtec model....its gonna be lines calipers and rotors....i just dont want the kit not 2 fit my spindle.....please help
Old Mar 4, 2006 | 12:38 AM
Entaka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">
Any idea what this involves? I think you just helped me figure out why im throwing a code 15 ::
Old Mar 4, 2006 | 03:22 AM
BDRphaSe2's Avatar
when i swapped my h23a1 to h22 jdm i used my oem harness just wired up vtec solenoid all obd1 but i used my h23a1 dizzy works and pulls great
Old Mar 4, 2006 | 09:22 PM
Entaka's Avatar
Default Re: (BDRphaSe2)
sure enough, i swapped out the distributor and the CEL is gone. my engine still wont start though. I think my fuel pump gave up on life
b18cvtec
Jul 23, 2013 06:56 PM
vtakk eg
May 6, 2009 04:01 PM
LukieLuc
Jun 6, 2008 02:55 PM
darockstar
Jun 9, 2006 10:19 AM
Gerst240
Oct 30, 2003 11:25 AM
