Compression on h22a
Old Jun 2, 2007 | 07:28 PM
JasonST's Avatar
Default Compression on h22a
So it started out yesterday when I was at the track and I misshifted going from 3rd to 4th, it wouldn't go in for some reason and I tried so hard it went into second, and the rpms sky rocketed. Anyways, I noticed the car started to jerk a little bit in gear but the enging still ran fine, sounded fine, and idled fine, but on my next run I did horrible, I got a 15.4 which is horrible because I thought I did great that run but my car felt slower. So when I got home I did a compression test to see if I bent any valves or anything. Compression was 230-240 all the way across. So i'm still at a loss here what could have happened and what could have been damaged? Also, is that good compression for a jdm h22a? Thanks.
Old Jun 3, 2007 | 01:39 AM
MYKJDM's Avatar
Default Re: Compression on h22a (JasonST)
dont mean to jack this thread but HOW DO YOU DO A COMPRESSION CHECK??
Old Jun 3, 2007 | 04:45 AM
prelude_h22vtec's Avatar
that compression is damn good actually. anything 210 or more is good....as long as they are within 10% of each other. maybe its in your head, do you do alot of drag racing?
Old Jun 3, 2007 | 07:12 AM
JasonST's Avatar
Default Re: (prelude_h22vtec)
Sweet I'm glad the compression is good... Actually I don't do alot of drag racing, that was my second time ever, 3rd and 4th run ever. But the thing is last time stock for my h22 I got 15.1, and I didn't have any practice, I'm still not too experienced but not I got I/H/E and the best I could pull off is 15.4. Maybe it's cause it keeps giving me a cel for the tps. I can't figure out how to fix it, I swapped out 2 tps sensors, calibrated them to .45V, checked em again and again and still get the code. Also checked my wires for continuity.
Old Jun 3, 2007 | 07:32 AM
mattsnooz's Avatar
Default Re: (JasonST)
yeah somethings really wrong. i got just over 15.2s in my stock 2.3L sr4ws
with the worst tires immaginable too lol
Old Jun 3, 2007 | 08:12 AM
i dont think anything's wrong, other than that tps thing. but that's not going to result in a huge power loss
Old Jun 3, 2007 | 09:44 AM
Prudz_lude's Avatar
i think you just need more practice driving to be honest
Old Jun 3, 2007 | 09:55 AM
I-4's Avatar
I-4
Where and how do you do the copresion test ? If it's a shop, is it expensive?
Old Jun 3, 2007 | 11:12 AM
JasonST's Avatar
Default Re: (I-4)
you buy a compression tester at an automotive store. Anyways, another question, when do u know that u need to adjust ur valves? I hear them ticking ( i think) but it's not very loud and only in lower rpms.
Old Jun 3, 2007 | 11:16 AM
93sivtec's Avatar
What kind of exhaust and header do u have......u may have made ur prelude slower
Old Jun 3, 2007 | 11:28 AM
JasonST's Avatar
Default Re: (93sivtec)
I got a dc sports header and down pipe, but i got a nice tanabe hyper medallion exhaust, shoulda add alot more power than stock, it's 2.36 piping, I'm still usin my stock cat though.
Old Jun 3, 2007 | 04:40 PM
ethereal2pt2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">you buy a compression tester at an automotive store. Anyways, another question, when do u know that u need to adjust ur valves? I hear them ticking ( i think) but it's not very loud and only in lower rpms.</TD></TR></TABLE>
you just answered your own question.
Old Jun 3, 2007 | 04:54 PM
mattsnooz's Avatar
Default Re: (_BB6)
yeah. feel your spark caps. if you can feel them bouncing/smacking alot you need to adjust them (or hear that little tick)(your hear a knock than your in shiet). Needed Valve adjustments arn't going to kill your power though if its a light tick like you indicate.
stock cat is steming your exhaust flow either way (depending on age it could be garbage maybe?)
open your cat or get a high flow performance one.
maybe your cat is plugging or plugged.
sounds like motor could be fine though, maybe your tranny is doushed
Old Jun 5, 2007 | 02:06 AM
BB1 H22A LUDE's Avatar
Default Re: (mattsnooz)
" if you can feel them bouncing/smacking alot you need to adjust them (or hear that little tick)(your hear a knock than your in shiet)" What do you mean by a knock? My lude is in need of valve tunning, should get it done in a few weeks, but my lude sounds kinda wierd. It almost sounds like when u take a bolt and tap the aluminium block. Is that a normal valve lash sound or is that a knock, if it is what needs to be replaced?
Old Jun 5, 2007 | 04:15 AM
mattsnooz's Avatar
Default Re: (BB1 H22A LUDE)
a knock is very distinguishable from a tick. go knock a wooden block against a metal block and it will sound kinda like that. A tick is quieter and is usually only really noticible at idle like a moron clicking his pen non stop
the knock would be allover power band and very noticible "clunk clunk clunk"
also to isolate sounds use a long hallow tube (im using 3/4" pvc pipe). If you listen down the tube and point the end at certain area's its able to show you where sounds come from. hold the other end right above valves and listen. The tick is from there. A clunk will come from your block. (block is on bottom, head is where valves and exhaust/intake ports are)
if its a knock get ready for a motor teardown lol (sorry if thats your case )
Old Jun 5, 2007 | 06:25 AM
JasonST's Avatar
Yeah it's definately a tick. guess i'll have to check the valve lashes then. Thanks for the help.
Old Jun 5, 2007 | 06:44 AM
mattsnooz's Avatar
you can pinpoint which valves in specific need adjustments, by listening how i described (stethoscope works perfectly) but mayaswell reset all valves while your inthere.
don't go too tight if its your first time setting valves. go to spec exactly or go a fraction less.
Old Jun 8, 2007 | 11:38 PM
Hey, i kinda found the location where the tapping sound is comming from, it seems to be comming from the exhaust manifold. Is this were you are supposed to hear valve lash? Is it possible to tell if valves are burnt? Im starting to wonder about mine, the sound is continous through the rev range but its not a constant sound, when reving it several times in a row, it gets significantly louder and then softer at random intervals. I guess ill really see whats going on when the valves get tuned.
Tonydalude
Apr 10, 2005 08:31 PM
ItalynStylion
Aug 4, 2004 12:59 PM
chinhead1228
Jun 17, 2003 05:51 PM
Bombino
Apr 15, 2002 01:13 PM
hybrid22l
Mar 5, 2002 04:23 PM
