Just did a compression test
Old Jun 6, 2007 | 07:11 AM
jardolei's Avatar
Default Just did a compression test
I have read a LOT of posts on compression on HT so I did my own and I got 180-180-170-175. The thing is I don't know if its actually any good since almost all the posts are for modded engines. Mine is stock 97 H22A4
The only thing I forgot was to do the wot while tuning the ignition. Does that actually change anything? Up compression or lower?
Thanks for you "quality" feedback
Old Jun 6, 2007 | 07:20 AM
577HondaPrelude's Avatar
Default Re: Just did a compression test (jardolei)
WOT while tuning the ignition will give you higher numbers. Those numbers look fine for a OEM engine.
Old Jun 6, 2007 | 08:50 AM
Mikey3000's Avatar
the rule of thumb to know whether its good or not is if the difference between the lowest and highest number is less than 10% then your good.
Old Jun 6, 2007 | 09:12 AM
jardolei's Avatar
Default Re: Just did a compression test (Mikey3000)
Yeah but what if I would have got 150-150-140-145 ???
Then wouldn't have ben good either. Most of the posts give around 200-250.... so I was wondering why I was getting 180-170
Old Jun 6, 2007 | 09:49 AM
180 to 195 is normal for OEM H22a4, and you porb. would get 190ish if you had WOT during your test. 200-250 is what you get with higher compression ratio than 10:1
If you are down at 150 that's too low.
Old Jun 6, 2007 | 09:55 AM
Mikey3000's Avatar
its unlikely that all cylinders would read that low simultaneously.
Old Jun 6, 2007 | 10:50 AM
dagle's Avatar
mine at 127k is 210 accross.. only mod is intake.
Old Jun 6, 2007 | 11:00 AM
jardolei's Avatar
Default Re: Just did a compression test (dagle)
Yeah but is it a H22A4? did you do it on wot? If it is then mine seems a little low....
But 577HondaPrelude says its normal, so why the hell is every one getting over 200 on average?
mileage = 105k
Modified by jardolei at 3:17 PM 6/6/2007
Old Jun 6, 2007 | 02:59 PM
I-4's Avatar
I-4
How do you do a compresion test ?
Old Jun 6, 2007 | 03:05 PM
I-4's Avatar
I-4
nvm got it
Old Jun 6, 2007 | 04:55 PM
mattsnooz's Avatar
depends on how babied the motor was too. If the seals are solid the compression is going to hold well and thus be higher
Old Jun 6, 2007 | 05:41 PM
bb4socal's Avatar
Well...for those guys that have high numbers...take into consideration that they might have significant amounts of carbon buildup in the combustion chamber. I think its possible. The oem specs for compression from the Manual are from 135- 180 psi or so. And if i remember each cylinder must be within 21 or 28 psi of eachother. just my 2cents
puma2132
Feb 8, 2009 02:37 PM
guero2craze
May 8, 2007 09:15 PM
turbotime
Oct 1, 2005 08:46 AM
Norcalstoppy
Nov 21, 2002 12:55 PM
MechEng
Feb 11, 2002 06:15 PM
