trouble code p1399
Old Jun 4, 2007 | 09:04 PM
ericdachampion86's Avatar
Default trouble code p1399
this is the only info i can find on this code. VW-- faulty glow plug. Chrysler/Dodge-- Wait to start lamp. What does it mean for a honda? Surely to god my computer doesn't think i need to change glow plugs in a h22a. lol. that would be a new one! Its also throwing these codes. P0301-- cyl 1 miss. p0302-- cyl 2 miss. P01300-- multi cyl miss. Ive tried nearly everything the car still has a miss. The only time it misses is when its NOT under a load. Ive done plugs, wires, dist cap, rotor button, icm, compression check all is good, adjusted the valves for kicks, new tps (adj by voltage), new fuel injectors, new fuel filter, checked the strainer on fuel pump, have good fuel pressure, replaced ALL vacuum lines and checked for leaks. Any suggestions cause i'm lost. Could it be my ECU?
Old Jun 5, 2007 | 06:09 PM
Default Re: trouble code p1399 (ericdachampion86)
bump
Old Oct 30, 2007 | 01:57 PM
all-mtr-teg's Avatar
Any update, im getting the same 0301, 0303, 1300 and 1399 codes
Old Nov 4, 2007 | 11:14 AM
preludepower420's Avatar
P1399 is either a Crank sensor or a TDC sensor I get the same **** and a 1301 to go along with all the misfires (p0301, p0302, p0303, p0304) as well as the random misfire (p0300). I always thought it was because of my distributor (OBDI on a JDM in a OBDII car) . What distributor are you guys running?
Gh86
Sep 21, 2017 10:22 AM
vedha
Sep 30, 2013 02:10 PM
ludehatchridder
Oct 27, 2010 06:14 AM
dis_epix3
Aug 31, 2006 03:52 PM
mstealth22
Jun 4, 2004 10:05 AM
