Brian Crower Stroker Kit
Old Oct 30, 2007 | 06:59 AM
lude98SH's Avatar
Default Brian Crower Stroker Kit
Has anyone delt with this company and in particular this kit itself ? According to pocketrocketsracing they are made in china. Not that thats bad its just that normally products from china are well....junk. However I havent heard anything bad about them either. Their are other companies that make stroker kits for the hseries however they are more expensive. I dont have a problem with paying more however that money spent has to equal more quality not just a better name. I have also heard crower makes a kit with a 102mm stroke however i havent seen it on their site....... ?
http://www.briancrower.com/view.php?pn=BC0036
http://www.briancrower.com/mak...shtml
http://pocketrocketsracing.com/mainchcrstki.html
Old Oct 30, 2007 | 07:01 AM
mgags7's Avatar
Firstly, don't deal with pocketrockets, they're sketchy.
Brian Crower knows what he's doing. Email him if you want info on anything, I'm sure he'll help you out. I wouldn't spend the $$ on one of these though, I'd look into modifying a k24 crank to work with an h block. 99mm stroke = secks
Old Oct 30, 2007 | 07:04 AM
lude98SH's Avatar
Default Re: (mgags7)
yea i just read that off their site that they were china made, im not planning on buying anything from them.
Old Oct 30, 2007 | 07:06 AM
kb58's Avatar
Banned
i second that. After it's all said and done, look at what you get for your money. It doesn't take much to make a K24 swap a simpler, cheaper approach. A full stroker engine is very expensive.
Old Oct 30, 2007 | 07:10 AM
lude98SH's Avatar
Default Re: (kb58)
well ive heard of many ppl with s2k's going k24 crank, and h22 pistons and rods. I cant really find much about people using them in an h22 block.
https://honda-tech.com/zerothread?id=1683773
Old Oct 30, 2007 | 07:23 AM
98vtec's Avatar
moderator emeritus
Default Re: (lude98SH)
what are you trying to accomplish?
Old Oct 30, 2007 | 07:35 AM
mgags7's Avatar
You're not going to "hear" anything about exactly what it takes, but you can make it work. Get a crank, take it and the block to a machine shop, check it out.
Old Oct 30, 2007 | 08:22 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Firstly, don't deal with pocketrockets, they're sketchy.
Brian Crower knows what he's doing. Email him if you want info on anything, I'm sure he'll help you out. I wouldn't spend the $$ on one of these though, I'd look into modifying a k24 crank to work with an h block. 99mm stroke = secks</TD></TR></TABLE>
Interesting.....
I remember seeing a build where they used an H series crank in a K series build. I wonder what that was all about!?
CROWER They'll never get $1 of my money. Thrilled to have sold the shortblock I had with Crower rods!
Old Oct 30, 2007 | 08:57 AM
mgags7's Avatar
Default Re: (::NirVTEC::)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: &raquo;</TD></TR><TR><TD CLASS="quote">
Interesting.....
I remember seeing a build where they used an H series crank in a K series build. I wonder what that was all about!? </TD></TR></TABLE>
Bore centers and main journal sizing being "compatible" has a lot to do with why you can interchange these cranks. I'd assume they were building a high rpm engine if they used an h22 crank.
Old Oct 30, 2007 | 09:15 AM
Televator's Avatar
I've heard about the interchangeability of cranks among H/F/K series. Would this also mean all the other rotating bits between H/K are also interchangeable? Like say, K24 rods on a H series crank? I believe the BE bores are the same size, but that's all the info I have. I guess you'd never know until you try...
Old Oct 30, 2007 | 10:03 AM
mgags7's Avatar
K rods are more narrow than H rods, so no they won't work on an H crank.
The other way around could work though.
If you need rods, you can always offset grind for a bit extra stroke and use b rods.
...or just grind it down normally to use them, but who would want to do that?
Old Oct 30, 2007 | 10:30 AM
Televator's Avatar
Thanks Matt...for killing my dreams. J/K I do appreciate your input, but what do you mean by "narrow"? I'd imagine that "narrower" applies to B rods thus why the offset grind is required. Unless you meant to say that the K rods are broader on the big end...
Anyway to remain somewhat on topic. Isn't "Brian Crower" Separate from "Crower"?
Old Oct 30, 2007 | 11:11 AM
117's Avatar
117
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ::NirVTEC:: &raquo;</TD></TR><TR><TD CLASS="quote">I remember seeing a build where they used an H series crank in a K series build. I wonder what that was all about!?</TD></TR></TABLE>
What did they do about the oil pump?
Old Oct 30, 2007 | 11:18 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (kb58)
Interesting.....
CROWER They'll never get $1 of my money. Thrilled to have sold the shortblock I had with Crower rods! </TD></TR></TABLE>
Crower is not the same as BC...
Old Oct 30, 2007 | 11:29 AM
mgags7's Avatar
Default Re: (Televator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Televator &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Matt...for killing my dreams. J/K I do appreciate your input, but what do you mean by "narrow"? I'd imagine that "narrower" applies to B rods thus why the offset grind is required. Unless you meant to say that the K rods are broader on the big end...
Check this out, I got my info off Crower's website:
<u>BE Width:</u>
B series: .935"
H/F: .935"
K/F23: .780"
F20C: .940"
<u>BE Bore:</u>
B series/K20A3/F23: 1.890"
K20A/K24/H/F : 2.008"
So, in order to use B series rods on an H crank, you need to grind the excess .018" off, you can either grind on center, and simply shrink the journal. Or, you can offset grind, which means that you'll grind more off the inside of the journal and less off the outside, which will more the axis of rotation outward, which is an increase in stroke.
K24 rods are too narrow as you see, and there is no grind that can fix that. However, you can grind out a journal to be wider in order to fit a wider rod on the crank, like putting an H22 rod on a K24 crank
Old Oct 30, 2007 | 11:31 AM
mgags7's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">
What did they do about the oil pump?</TD></TR></TABLE>
They just regrind it to fit, I'm not sure of exactly the modification procedure, but I heard that the snout is all that needs to be changed. I wonder what you would encounter on the rear main/flywheel side though....
Old Oct 30, 2007 | 12:27 PM
Televator's Avatar
Oh, I see.
I totally get the concept of offset grinding, but I would feel nervous about removing material from such an integral area of the crank. Hell, knife edging counterweights makes me squeamish.
Old Oct 30, 2007 | 12:50 PM
mgags7's Avatar
Knife edging is more dangerous than offset grinding rod journals IMO.
When you knife edge the crank, you're removing material from the counterweights, which 9/10 times a crank actually breaks, are what break.
The rod journal is still plenty strong at almost 2", **** v8s use BE sizes around the same as H22s do, and they have twice the stress put on them, plus the journals are wider, and they still hold up.
edited: I meant counterweights. not journals, in the knife edging part
Modified by mgags7 at 7:15 AM 10/31/2007
Old Oct 30, 2007 | 12:56 PM
bigz187's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Knife edging is more dangerous than offset grinding rod journals IMO.
When you knife edge the crank, you're removing material from the journals, which 9/10 times a crank actually breaks, are what break.
The rod journal is still plenty strong at almost 2", **** v8s use BE sizes around the same as H22s do, and they have twice the stress put on them, plus the journals are wider, and they still hold up.</TD></TR></TABLE>
Some good info in here guys
Old Oct 30, 2007 | 12:58 PM
98vtec's Avatar
moderator emeritus
knife edging and journals? pretty sure you are removing material from the hammer to reduce weight and attempt to reduce windage losses...
Old Oct 30, 2007 | 01:24 PM
Televator's Avatar
Default Re: (98vtec)
^^That's what I meant by "counterweights". I'm sure Matt just had a slip of the tongue.
Old Oct 30, 2007 | 06:44 PM
lude98SH's Avatar
interesting. However how much is machine work for that going to run ?
Old Oct 30, 2007 | 11:14 PM
hu's Avatar
hu
Default Re: Brian Crower Stroker Kit (lude98SH)
Frank buys his 100mm stroker from BC.
Old Oct 31, 2007 | 03:17 AM
mgags7's Avatar
the ol slip of the fingers. but yeah, counterweights is what I meant.
Scott (2point6) recently did an f23 crank + offset grind to use b series size rods and he got 97.75mm of stroke when all was said and done. Check out his build thread, it was floating around here not too long ago.
Machine work on stuff like this can get expensive, find a good shop. Castillos does good work in Cali.
billabongkid13
Jan 27, 2008 09:08 AM
90 integra
Oct 8, 2004 03:26 AM
TEG2001
Aug 30, 2002 06:47 PM
w1se
Mar 9, 2002 09:33 AM
