test pipe or high flow cat
Old Oct 23, 2007 | 09:03 PM
ninety3lude's Avatar
Default test pipe or high flow cat
i know they both have the same purpose but high flow cats are pretty expensive. im asking if there is a noticeable benefit from a cat as to just welding your own pipe for a lot cheaper. my only concern would be the o2 sensor.
Old Oct 23, 2007 | 09:06 PM
Hawkze_2.3's Avatar
Default Re: test pipe or high flow cat (ninety3lude)
A noticable difference? Of course! Lets see...you will be polluting the environment even worse, you won't pass inpection, you will have to fool your ECU into thinking you have a real cat (or have a CEL on all the time ), and your car will sound crappy.
If it's too expensive for you to get a high flow cat, then just don't get anything.
Old Oct 23, 2007 | 09:07 PM
no1knows908's Avatar
I've used a resonated and straight test pipe and finally decided to go with a high flow cat. Tests prove that on a NA car that the HP differences are minimal... IMO the smell and raspy sound aren't worth the maybe 1 HP difference.
Old Oct 23, 2007 | 09:32 PM
Acidcrakker's Avatar
Yeah High flow def. I got me a resonated test pipe right now(its illegal) someone is selling me a high flow in a week. The car smells like bad exhaust right now.
Old Oct 23, 2007 | 09:40 PM
98vtec's Avatar
moderator emeritus
Default Re: test pipe or high flow cat (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">A noticable difference? Of course! Lets see...you will be polluting the environment even worse, you won't pass inpection, you will have to fool your ECU into thinking you have a real cat (or have a CEL on all the time ), and your car will sound crappy.
If it's too expensive for you to get a high flow cat, then just don't get anything.</TD></TR></TABLE>
Old Oct 24, 2007 | 02:37 AM
BlackCatt's Avatar
Get a high flow cat or just leave current setup until you can afford one.
Old Oct 24, 2007 | 05:13 AM
JT's Avatar
JT
Here is a comparison between a 200 cell cat and a test pipe, both in 2.25" dia. The dyno is from a K24, but you get the idea there's not much of difference in gain for NA application. The blue is the test pipe.
Old Oct 24, 2007 | 10:24 AM
dumkopf's Avatar
High-flow cat expensive? I don't think so.
http://www.kteller.biz/prodtyp...y=cat
For around 88 bucks+ shipping you can have one. They can even make custom ones.
Old Oct 24, 2007 | 09:05 PM
HONDA RR's Avatar
Test pipe .
Old Feb 27, 2008 | 11:14 AM
JDM R Cooker's Avatar
Default Re: test pipe or high flow cat (HONDA RR)
Does a test-pipe have one socket for 02 sensor? Y does my check engine light comes on ?
Old Feb 27, 2008 | 11:17 AM
A Blue Lude's Avatar
Default Re: test pipe or high flow cat (JT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">Here is a comparison between a 200 cell cat and a test pipe, both in 2.25" dia.</TD></TR></TABLE>
for good information.
Old Feb 29, 2008 | 12:52 PM
jtaylor16's Avatar
I know you probably dotn need any more opinion but, high flow cat
Old Feb 29, 2008 | 02:39 PM
autoluder's Avatar
obd1 o2s are before the cat, test pipes dont throw cels for us forth genners
Old Feb 29, 2008 | 05:59 PM
98vtec's Avatar
moderator emeritus
Default Re: test pipe or high flow cat (autoluder)
street car = high flow cat
race car = open header (no test pipe, no exhaust)
stop polluting the air in your STOCK motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">Here is a comparison between a 200 cell cat and a test pipe, both in 2.25" dia. The dyno is from a K24, but you get the idea there's not much of difference in gain for NA application. The blue is the test pipe.
good post. The test pipe would gain a little more power if the mixture was richened up a little bit. Nevertheless, good post.
Old Feb 29, 2008 | 10:37 PM
95greenlude's Avatar
Default Re: test pipe or high flow cat (98vtec)
test pipes make your car sound like ***....
on a WS2
test pipe:
stock cat:
http://videos.streetfire.net/v...3.htm
my car both times....and polluting is bad!
Old Mar 1, 2008 | 12:17 AM
Default Re: test pipe or high flow cat (01electrolude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01electrolude &raquo;</TD></TR><TR><TD CLASS="quote">Does a test-pipe have one socket for 02 sensor? Y does my check engine light comes on ? </TD></TR></TABLE>
As I can see you are the bumper of old threads here. To awnser your question, my test pipe does have a spot for an 02 sensor.
IDK why your CEL light comes on, you are going to have to be more specfic as to what code you are throwing.
Old Mar 1, 2008 | 06:10 AM
SMSP's Avatar
Default Re: (dumkopf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumkopf &raquo;</TD></TR><TR><TD CLASS="quote">High-flow cat expensive? I don't think so.
For around 88 bucks+ shipping you can have one. They can even make custom ones. </TD></TR></TABLE>
The above are some smaller Carsound cats with 400 cell ceramic substrates. They flow more than stock mainly because they have larger outlets than stock. But a 300 or 200 cell cat will flow even more. My 2-1/2" 300 cell metal substrate cats flow around 365 cfm @ 28 inches where my 200 cell metal substrate cats flow around 440 cfm.
Old Mar 1, 2008 | 08:36 PM
snzh22's Avatar
Default Re: (SMSP)
95green: was ur TP resonated? if not, that could be why it sounded so bad. i just went from unresonated tp to resonated by megan and it sounds a lot better than before.
recon23
Jan 8, 2008 10:37 AM
DCSportEJ1Civic
26
Jul 16, 2007 12:44 PM
ohnoitssoysauce
Sep 12, 2004 10:53 AM
p1ccoloz
Mar 6, 2003 09:32 AM
808State
May 14, 2002 11:12 AM
