VSS help
Old Oct 26, 2007 | 06:37 AM
john22's Avatar
Default VSS help
hi wandering if anyone can help. I need a new vehicle speed sensor as im getting code 17 and 31 i cant seem to find 1 anywhere. I've phoned honda the only thing they could find was a pick up sensor i thought that wasnt the same thing so i left it. any help would be great. Its an automatic 2.2 jap import 92 bb1.
Thank you
John
Old Oct 26, 2007 | 08:01 AM
Hawkze_2.3's Avatar
Default Re: VSS help (john22)
Is it an H22? You can order any OEM parts you want from http://www.hondaautomotiveparts.com or http://www.slhondaparts.com.
Old Oct 26, 2007 | 11:13 AM
john22's Avatar
yes its a h22a i am from the uk any websites that sell parts here?
Old Oct 26, 2007 | 11:39 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john22 &raquo;</TD></TR><TR><TD CLASS="quote">yes its a h22a i am from the uk any websites that sell parts here?</TD></TR></TABLE>
I'm sure there are some but I don't know them...you might find one on eBay though, there's a lot of OEM parts stores on there that ship worldwide.
Before you buy anything though get in there and check out your VSS. There are several different things that could cause a code. You have the actual little black plastic sensor, the larger metal shaft with the gears inside, and even check the wiring connectors and the pins inside for corrosion. The VSS plug sits vertically so it's easy for liquid to just sit there for long periods of time and corrode stuff.
Old Oct 27, 2007 | 01:34 AM
john22's Avatar
Default Re: VSS help (Hawkze_2.3)
thanks for the advice if i `can find where the speed sensor is i wil inspect and try to clean it. Just having a little trouble finding it unlessits write t the back of the gearox underneath the thrttle body.???
Old Oct 27, 2007 | 10:04 AM
Hawkze_2.3's Avatar
Yep, striaght down from the TB on the transmission. You'll need a flashlight and a long extension.
aionic
Jun 20, 2008 08:19 PM
meltman1234
Honda Motorcycles
Dec 13, 2007 03:44 PM
2fastGSR
Oct 22, 2007 01:10 PM
Rob.
25
Oct 20, 2007 06:37 PM
mtg4gen
May 14, 2007 04:39 PM
