Small oil problem
Old Oct 23, 2007 | 05:42 PM
93SiPrelude's Avatar
Default Small oil problem
The boot on the joint on the steering rack has a slight crack in it. it looks like an oil line is actually going to the boot. true? and when i start my car on the oil pressure comes on like it should when you start it but it stays on for an extra 4 or 5 seconds. any ideas?
Old Oct 23, 2007 | 06:38 PM
Acidcrakker's Avatar
Default Re: Small oil problem (93SiPrelude)
you dont need a poll for this
Old Oct 23, 2007 | 06:58 PM
ECX's Avatar
ECX
* B A N N E D *
lol at the poll options. outstanding!
Old Oct 23, 2007 | 09:14 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiPrelude &raquo;</TD></TR><TR><TD CLASS="quote">The boot on the joint on the steering rack has a slight crack in it. it looks like an oil line is actually going to the boot. true? and when i start my car on the oil pressure comes on like it should when you start it but it stays on for an extra 4 or 5 seconds. any ideas?</TD></TR></TABLE>
Wow...you're very lost There is no oil line attached to any boots on anything. There is a vacuum line on the boots to let the pressure escape from one side to the other when you turn the wheel, but thats' it.
My idea for you would be to replace the boot so your rack doesn't wear out and don't worry about the oil light (as far as the PS rack is concerned anyway). You may have an oil pressure problem but that would be a different story...check the oil level first.
Old Oct 24, 2007 | 04:07 AM
typeS's Avatar
That is probably power steering fluid. You will want to check your fluid level. I have found that after you drain and fill the power steering fluid a couple times it usually stops leaking.
Old Oct 24, 2007 | 01:58 PM
ethereal2pt2's Avatar
Default Re: Small oil problem (typeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX &raquo;</TD></TR><TR><TD CLASS="quote">lol at the poll options. outstanding!</TD></TR></TABLE>
i was too scared to vote opt #1. i failed..
Old Oct 24, 2007 | 04:27 PM
Ralleh's Avatar
Best post I have ever seen.
Old Oct 24, 2007 | 07:29 PM
s13_240sx_92's Avatar
ibtl
NIGHTRIDER27
Apr 9, 2008 06:51 PM
nebulight
Sep 6, 2006 06:26 AM
5thgen
Jul 2, 2006 07:43 PM
SpoolinEK
Welding / Fabrication
Aug 29, 2004 10:21 AM
97F22B2
Jun 10, 2004 08:29 PM
