why?
Old Oct 25, 2007 | 09:02 PM
jaskuloski97sh's Avatar
Default why?
anyone have any idea why im ideling so damn low. ive searched and searched and posted with this same problem and no luck. ive listened to ideas and now i have a new throttle body gasket, new intake manifold gasket(am using a skunk 2 manifold), new iac, new fitv, new pcv, and new filter for inake jus cuz it was dirty. tried two different ecu's. p13 with obd 2 to obd 1 conversion harness. and the p5p that came with the SH motor wich i swaped for jdm. idles at 250. with the p5p when i turn a.c. on idle drops and stays low. when i use the p13 it drops then raises to bout 450 500ish. oh and the idle on cold start is fine but when i reach operating temperatures it drops to the above stated level. please guys any help is appreciated. thanks in advance!
Old Oct 25, 2007 | 09:29 PM
h23vtecpowered's Avatar
Default Re: why? (jaskuloski97sh)
https://honda-tech.com/zerothread?id=1979500
Old Oct 25, 2007 | 09:36 PM
Default Re: why? (h23vtecpowered)
when did i say idle bounce? i read this thread before and ya i listened then jus incase i replaced both valves with brand new ones like i said. i guess i explained it wrong. this is not an idle bounce at all. as the car warms up the idle continues to drop down lower and lower.
Old Oct 25, 2007 | 09:38 PM
Hawkze_2.3's Avatar
Try adjusting the throttle cable, idle screw and the valve lash and see if that helps.
Old Oct 25, 2007 | 09:41 PM
Default Re: why? (Hawkze_2.3)
by idle screw do you mean the screw that gives more or less air to the iac? god im gonna hate my self for this but what do you mean by valve lash?
Old Oct 25, 2007 | 09:44 PM
Hawkze_2.3's Avatar
No problem, the idle screw is on the throttle body and it raises/lowers the idle regardless of the IACV...it's right on top of the TB, and it might have a layer of wax if it's never been touched, but you can remove that.
Valave lash is what's adjusted when you do a valve adjustment. It can get out of spec and cause idle/performance issues. It's a bit complicated to do if you haven't done it before, but there's many write-ups and such online. One in the Prelude FAQs even
Old Oct 25, 2007 | 09:52 PM
well i got a little ticking cuz i never adjusted the valves after the swap but now that you explained it that seems to ring a bell so ya ima try the valve adjustment first. ill let ya no what happens with that but thanks alot thats the only new idea anyone has given me for awhile and sounds like a good one. thanks again!
Old Oct 25, 2007 | 09:56 PM
Hawkze_2.3's Avatar
lilhalfsquat54
10
Nov 22, 2017 07:37 PM
Afflicted1
50
Mar 4, 2014 09:46 PM
Todhunter
Nov 23, 2010 12:55 PM
thebleek
81
Mar 18, 2009 10:47 PM
greenlx777
May 24, 2005 12:28 PM
