Fog light install with jdm switch?
Ok so i bought the jdm skinny foglight switch for (93 console)
I searched and people said there was a connector in the dash wiring behind the left tweeter cover.
Well i did the el gauge conversion, so its not there.
I had my fogs hooked up to city lights/headlights but now i want them to be turned on through the jdm switch.
My question is can i just ground the switch hook it up to the fogs and to my battery?
How can i do this without a oem fog connector?
Please Help
Thanks Rob
Please Help
Thanks Rob
Re: Fog light install with jdm switch? (prelude-all-the-way)
If that's the fog switch you got, it's for the 94+ models it goes in the center console.
If your car is a 92 or 93 model your plug/harness would be behind the tweeter cover look for it, if it's a 94+ it's under the center console taped with blue tape. I believe the USDM plug won't work on the JDM switch without some modification.
If you want to use the switch, you need the fog harness. Mine was the tweeter cover style. If you had factory fogs, you'd already have that harness. Since you had fogs connected to city lights though I'm going to assume that you need to buy that harness.
Re: Fog light install with jdm switch? (Televator)
since i have the 94+ harness and 93 console i dont have the harness so would i have to give up my el gauges or could i wire it another way?
TaboR
11-30-2001 07:54 AM
