02 Sensor worth changing?
Old Oct 28, 2008 | 09:49 PM
firaga21's Avatar
Default 02 Sensor worth changing?
It cost me around $250 at autozone. Ive been told that I could just unplug my battery and let it reset (check engine light), but that my gas mileage and such would suffer a little. I love my Ludie and want it running straight and right, not half ***. Is it true about it effecting my car like that? Or should I just got and get my refund? Thanks
Old Oct 28, 2008 | 09:50 PM
vinuneuro's Avatar
Default Re: 02 Sensor worth changing? (firaga21)
The oem oxygen sensor is only $40 from sparkplugs.com , I'd return the one you bought. It's a good idea to replace the primary sensor if it's got a lot of miles on it.
Old Oct 28, 2008 | 10:02 PM
firaga21's Avatar
Default Re: 02 Sensor worth changing? (vinuneuro)
Ive been told that the "Universal" ones dont really work well and I would need to splice wires and crap. The OEM, is it the same thing as the Universal?
Old Oct 28, 2008 | 10:47 PM
vinuneuro's Avatar
OEM= original equipment manufacture, as in that's the sensor that came in the vehicle from the factory. No splicing. NGK is the one you want from sparkplugs.com .
Old Oct 28, 2008 | 11:06 PM
firaga21's Avatar
Cool thanks, I looked up the Bosch part # on there and it was waaaaay less expensive- $95!! The NGK one is even MORE less expesive, thanks so much I really appreciate it. Last question- im not sacrificing quality by going with the less expensive NGK over the the more expensive Bosch sensor?
Old Oct 28, 2008 | 11:13 PM
vinuneuro's Avatar
NGK is what Honda uses, why would you use anything else? Same goes for all the ignition components, spark plugs and wires. Use oem, which is NGK.
Old Oct 28, 2008 | 11:19 PM
firaga21's Avatar
Awesome, thank you so much on all fronts!!!
Old Oct 29, 2008 | 12:23 AM
TheJGB3's Avatar
FYI - DO NOT USE A BOSCH O2 sensor on ANY HONDA OR TOYOTA! They don't work for some reason.
NGK o2 sensor division is NTK, and they make the OEM Honda ones.
Old Oct 29, 2008 | 06:05 AM
liukangus's Avatar
Default Re: (TheJGB3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheJGB3 &raquo;</TD></TR><TR><TD CLASS="quote">FYI - DO NOT USE A BOSCH O2 sensor on ANY HONDA OR TOYOTA! They don't work for some reason.
NGK o2 sensor division is NTK, and they make the OEM Honda ones.</TD></TR></TABLE>
"Plug n' play, motha-[freak]a!" - Gump
Old Oct 29, 2008 | 07:00 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheJGB3 &raquo;</TD></TR><TR><TD CLASS="quote">FYI - DO NOT USE A BOSCH O2 sensor on ANY HONDA OR TOYOTA! They don't work for some reason.</TD></TR></TABLE>
I have had a Bosch 02 for almost 5 years now without any problems on my Honda...spliced wires and everything
Old Oct 29, 2008 | 07:50 AM
Kronn 98SH's Avatar
Default Re: (Hawkze_2.3)
I'm running Denso sensors, $45 each. For $250, did they supply the vasoline?
Old Oct 29, 2008 | 08:48 AM
firaga21's Avatar
Default Re: (Kronn 98SH)
Lmao, no kidding!!! Your not the first one to say that!!! HAHA!
Old Oct 29, 2008 | 09:53 PM
TheJGB3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Hawkze_2.3 - I have had a Bosch 02 for almost 5 years now without any problems on my Honda...spliced wires and everything
Well consider yourself lucky. The owner of http://www.oxygensensors.com told me he quit selling them, because EVERY SINGLE one he sold to a Honda or Toyota owner ended up coming back defective. He does'nt recommend, nor will he sell any Bosch O2 sensors from now on.
Old Oct 30, 2008 | 07:35 AM
Hawkze_2.3's Avatar
Do you know of that was the universal ones that you splice the wires on or the plug & play sensors? I would bet a LOT of people mes up the wire splicing.
Old Oct 30, 2008 | 08:33 AM
no1knows908's Avatar
I went through two brand new Bosch OEM replacement sensor in a single month. Gave up and switched to a Denso sensor and have been fine for a year so far.
OogalyDoogaly
19
Apr 20, 2021 11:40 AM
Juniorhatch
Aug 25, 2010 10:45 PM
adorek24
May 10, 2010 04:30 PM
Mike1995HondaPrelude
Aug 31, 2007 02:11 PM
silentblackhat
Apr 3, 2005 03:26 PM
