having problems at 3000 rpms
Old Nov 9, 2008 | 03:45 PM
carlveitschegger's Avatar
Default having problems at 3000 rpms
Car spits and sputers at 3000 rpms and higher 94 prelude with f22a1 cant figure out what is causing this
Old Nov 9, 2008 | 04:06 PM
carnot's Avatar
Default Re: having problems at 3000 rpms (carlveitschegger)
Just a few suggestions
-check ignition components
-check battery connections and grounds
-check MAP sensor vacuum line and electrical connections
Old Nov 9, 2008 | 05:09 PM
Default Re: having problems at 3000 rpms (carnot)
we have replaced map sensor checked all vacum for leaks no leaks check all ignition now we do have a ground that is fryed a little but all are tight.\
Old Nov 10, 2008 | 09:36 AM
ShoofIsLudin's Avatar
change the ground that's burned up. Its probably not even working as a ground
D-seriousBis
Apr 11, 2013 05:07 PM
jordan_civic
May 30, 2008 10:35 PM
eg:R
Dec 21, 2006 03:14 PM
h22_crx
Dec 2, 2006 09:07 AM
