Overheating...
Old Oct 30, 2008 | 08:29 PM
95LudeSl's Avatar
New User
Default Overheating...
Alright, so I've looked around and have done everything I can think of but to no avail...
Just a few weeks ago, I picked up a 95 Si, and everything has been fine.
The radiator was replaced a week after I bought it, and the only aftermarket part is a SRI.
When I'm at idle, after driving for a while, and sit for roughly 5 minutes or so, my fans kick on, and my gauge will start climbing. One bar every few minutes. I have checked out everything I can think of but no luck. The T-stat is new from Honda, and I'm sure it is working fine as both of my tubes are hot, meaning circulation. The fans both kick in, so I don't see a problem there, and like I said, the radiator was recently replaced and I've cleared it for air in the system.
Can anyone give me a last resort as I don't want this motor to cause me any problems till I get some money for a swap.
Motor is an h23a1 with 232km!
Thanks again
Old Oct 30, 2008 | 09:09 PM
gstrudler's Avatar
Default Re: Overheating... (95LudeSl)
The gauge starts climbing after your fans kick on? Makes me wonder if the fans were put in backwards...
Old Oct 30, 2008 | 09:18 PM
ShoofIsLudin's Avatar
the way stock fans are mounted on 4th gens....it takes some fabrication to get the fans to sit backwards.
Are you sure ur fan is coming on?
when u bled the air from the coolant, did u have ur heater on?
My 94 does the same thing, and I just rigged the fan to turn on by a switch i mounted in the car. It hardly ever does it anymore, unless I really beat on it for an extended time, and then just come to an idle. On the highway tho...it'll drop to 1 bar on the dash, this highway cooling happened in July in FL wit the fan turned off. I figured the ram air effect would move more air than the fan
Old Oct 31, 2008 | 06:29 AM
95LudeSl's Avatar
New User
No, the fans come on like they should I believe, but just don't seem to keep the heat down. Both fans come on, as I've been popped the hood and waited, then they kick on, and a few seconds later I gain a bar on the heat gauge..
I didn't have my heater on when I bled the air...
Old Oct 31, 2008 | 07:37 AM
SKDRCR's Avatar
Default Re: (95LudeSl)
I would try bleeding the system again. Have you tested the
actual radiator cap itself?
Old Oct 31, 2008 | 08:24 AM
teambk8's Avatar
Default Re: (SKDRCR)
It could also be the temp sensor, I have a autometer gauge that tells me the temp and I have the one on the dash. Sometimes the one on the dash will say that the motor is hot when the autometer one says that its not... then when I take a laser temperature gauge and aim it on my block in different locations, the autometer one is dead on! I need to change the temp sensor but am waiting till I get a new radiator before the summer and just do everything all at once!
Old Oct 31, 2008 | 12:34 PM
saikou's Avatar
Also, check out all your grounds. A bad ground can lead to a faulty temp reading.
rolledthatho
Feb 8, 2011 10:57 PM
Mr. Em1
22
Oct 20, 2006 10:24 AM
djSALIX
Feb 12, 2006 09:04 AM
nickhans
Oct 28, 2005 07:46 AM
rasinhell
Feb 12, 2005 06:03 PM
