GLOW GAUGES ? and INSTALL ?
Old Nov 6, 2008 | 09:39 PM
syne's Avatar
Default GLOW GAUGES ? and INSTALL ?
hey i got sum used glow gauges . there in a case the km dont match my cars km so is there a way to turn them back ? is it possible to take the gauges out of the case and hook it glow gauges to my stock gauge case so the km would be from my lude.
i have never hooked them up before so could someone give me detailed instuctions please include where to hook them to my headlight switch so i can turn on the gauges with my headlights.. also need to know where to hook it up to the power source.
Old Nov 7, 2008 | 04:26 PM
ShoofIsLudin's Avatar
if u have an aftermarket headunit....use the orange (illumination) wire to light them up.
Or go to the fuse box, and use a multimeter and test for ~12.0ish volts when u turn the headlights on
Old Nov 8, 2008 | 04:21 PM
syne's Avatar
Default Re: GLOW GAUGES ? and INSTALL ? (syne)
ok i need help i just changed the gauges .i removed the speed tack needle and the fuel gauge needle to put on the gauges and now they both do not work niether does the odometer it wont count km can somone help me
Old Nov 9, 2008 | 12:00 PM
syne's Avatar
some must of had this problem
Old Nov 10, 2008 | 02:45 PM
did u put the needles back on right?
Did u plug the cluster back in???
Old Nov 10, 2008 | 11:16 PM
syne's Avatar
Default Re: GLOW GAUGES ? and INSTALL ? (ShoofIsLudin)
i did plug them in and put the needles in the correct spot
sublimnal
61
Nov 4, 2008 09:02 PM
nocturnaldragon
23
May 3, 2004 03:01 PM
Preludster
Sep 25, 2002 05:16 AM
y2kintegra
Jul 29, 2002 01:05 AM
