Dash Lighting
Old Nov 3, 2008 | 08:04 PM
woodj87's Avatar
Default Dash Lighting
I own a 94 lude with digital dash, i want to change the stock color to red. I know how to change the time, temp, and gas gauge piece. I not sure yet how to change the speedometer and rpm meter part.
Any knowledge on the topic would be helpful.
Justin
Old Nov 3, 2008 | 09:38 PM
Lovemy99Lude's Avatar
Default Re: Dash Lighting (woodj87)
I dont have an answer for you, but how did you change the color. would you know how to change the color on a 5th gen?
Old Nov 3, 2008 | 10:13 PM
Kronn 98SH's Avatar
Default Re: Dash Lighting (Lovemy99Lude)
5th gen is easy....remove the dash pieces and replace the bulbs with whatever color LED you want
Old Nov 4, 2008 | 05:04 AM
drbenne's Avatar
for the EL gauge the only way i know is using the sheets of clear red acetate paper. I changed my gas and temps to blue using this method. There are a couple of writeups for this, hit me up and ill try to find them for you.
Old Nov 4, 2008 | 05:23 AM
twentyhurtz's Avatar
Default Re: Dash Lighting (drbenne)
hey, ok we just got our first prelude last night, its a 93, the digital dash it kinda throwing us off, when we first cranked it, it was not showing any reading for the gas gauge, then we put 10 dollars worth in and it showed a reading, was this thing just slam out of gas or does it have to have so much in it to show a reading? thanks in advance
Old Nov 4, 2008 | 07:32 AM
woodj87's Avatar
Default Re: Dash Lighting (Kronn 98SH)
i'm not sure if this will help, but for the gas and temp gauge this is the site i found.
http://www.digmyhonda.com/h/st...elude
Justin
Old Nov 4, 2008 | 07:34 AM
woodj87's Avatar
im not sure what generation i have, im pretty sure mine is a bb1, does that mean it is a 1st generation?
Justin
Old Nov 4, 2008 | 01:03 PM
slamdlude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by woodj87 &raquo;</TD></TR><TR><TD CLASS="quote">im not sure what generation i have, im pretty sure mine is a bb1, does that mean it is a 1st generation?
Justin</TD></TR></TABLE>
http://www.autocheck.com/consu...de.do this link will tell you how to decode your vin to find out the year and lots more. Or you can search but bb1 is 4th gen.
Old Nov 4, 2008 | 09:11 PM
woodj87's Avatar
Default Re: Dash Lighting (slamdlude)
does anyone know where to find a diagram for how the main cluster is put together, without having to tear my own apart. It is my daily driver, and i'd like to have a foot on ground before i tear it out. Anything that will help would be great for a 4th generation. Thanks
Justin
Old Nov 5, 2008 | 05:42 PM
ShoofIsLudin's Avatar
As far as ur cluster goes....yes, if u put gas in it, and it gained a couple bars, it was just COMPLETELY out of gas. As long as the gas gains bars as u add fuel, and the temp goes up to halfway....it works fine.
About changing the color.........umm...seriously.... UNLESS you are really good with electronics and putting things back together I wouldn't bother
I destroyed my OEM EL cluster trying to do it. And messed up the RPMs on the JDM one I had installed from shaking it around trying to wrestle it back OUT of the dash to run wires.....thats just me tho
IF you do decide to do it....BE CAREFUL with the needles. When u get the needles off, there are 2 small phillips screws on each side of both needles that hold the gauge face onto the cluster. Behind the gauge face is a piece of clear plastic that spreads the glow from the "light source". There's 2 flourencent tubes that make the RPMs and Speedo numbers light up (what I just called "light source"). The only bulbs are for the high beams, blinkers, and SRS light.
I did mine red on the gas gauge, and temp gauge.... red digital gauges are in my future....
I got the red film/celophane/acetate from Party Supermarket, and it was like $5 for a whole roll.
Nomial17
Honda Civic (2006 - 2015)
Feb 17, 2009 04:13 PM
Prudz_lude
Feb 14, 2009 10:10 AM
lx130
Apr 1, 2006 08:08 PM
5lugSlug
Mar 5, 2005 07:09 AM
Kashi
Jan 17, 2005 05:56 PM
