transmission problems?
Old Oct 30, 2008 | 06:49 PM
hawtsoss's Avatar
Default transmission problems?
Ok so I installed a new master and slave clutch cyl on my 01 prelude and it will work alright when i first start driving it, but after a bit i will have to jam it into gear again and I can't figure out what the problem is, is there some sort of locking mechanism that is locking me out or is there still something wrong with the clutch or what is going on? I can't figure it out and I am now contemplating taking it to the shop on credit because i dont even know what to fix
Old Oct 30, 2008 | 06:52 PM
jjspec's Avatar
Default Re: transmission problems? (hawtsoss)
Sounds like you may need to adjust the push rod on the master cylinder. It may be slightly applied causing the fluid to not return until it sits a while. Good luck!
Old Oct 30, 2008 | 06:58 PM
hawtsoss's Avatar
that does sound possible, im pretty sure i had it all the way out though when the pedal isn't pressed, anything else it might be?
maniacthw
May 6, 2014 10:42 AM
shadow29485
Oct 21, 2007 06:52 PM
Honduh Uhcord
Oct 15, 2007 08:29 PM
Peasonrice
May 5, 2005 04:17 PM
JLange
Mar 31, 2003 05:53 PM
