Engine Fault Codes
Old Nov 3, 2008 | 12:35 AM
dr_g's Avatar
Default Engine Fault Codes
Guys,
Im getting an engine warning light on , fault code is one long dash followed by two short dashes - does anyone know what this code means and how to solve the problem??
Cheers,
Garth.
Old Nov 3, 2008 | 12:37 PM
gstrudler's Avatar
Default Re: Engine Fault Codes (dr_g)
DTC 12 is an EGR valve malfunction. Check the wiring and vacuum lines to the EGR valve and make sure everything is good. Next step is to clean the EGR valve followed by the EGR ports on the intake manifold.
Old Nov 10, 2008 | 04:00 AM
dr_g's Avatar
Spot on - cleaned the EGR valve (second time this year) and all is well again. It seemed a bit notchy in its action this time, so possibly time for a new one.
Cheers,
Garth.
Old Nov 10, 2008 | 10:26 AM
Windwalker's Avatar
Default Re: (dr_g)
What do you do to 'clean' the EGR valve
hollywood28601
Dec 27, 2010 11:09 AM
squarepusher
Mar 12, 2009 04:02 PM
petercampusa1
Dec 11, 2008 10:10 AM
QUAIJAI
Jan 21, 2005 12:46 PM
munscher
Nov 24, 2002 04:48 PM
