H23 wont start/replaced head gasket? Help
Old 03-30-2009, 02:32 PM
lil_mowgli's Avatar
Icon6 H23 wont start/replaced head gasket? Help
i just replaced my head gasket on my h23a1 and i tourqed all head bolts to specs,timed it perfectly changed spark plugs to correct firing order on distributor checked all vaccum hoses and wires and hoses, cant find anything! it sounds like a honda turning over but wont start. any ideas anyone?
Old 03-30-2009, 06:51 PM
h23prelude's Avatar
Default Re: H23 wont start/replaced head gasket? Help
check and re-check EVERYTHING you did,
reattach ground wires?
all sensors pluged back in?
distributor pluged in?
check rotor and cap
check spark plug wires are correctly pluged in
Old 03-30-2009, 09:31 PM
speedracer9k's Avatar
99% sure you have the distributor 180 out. Set timing at #1 tdc pull of the distributor and make sure all the marks line up on the groove
Old 03-31-2009, 05:39 AM
Hawkze_2.3's Avatar
Check the ECU ground on the thermostat as well as other grounds.
How are you checking the timing?
Old 03-31-2009, 09:30 AM
lil_mowgli's Avatar
i checked the timing on the crack sprocket buy the key mark and lined it up with the little arrow on the block
Old 03-31-2009, 09:41 AM
lil_mowgli's Avatar
when i had the firing order firing 1234 the car ran but ran like **** but when i switched firing order to 1342 the car turns over great but no start. any other ideas? its got 2 b something simple
Old 04-01-2009, 06:29 PM
lil_mowgli's Avatar
speedracer9k was completely correct thanks bro distributer was 180 out
Old 04-01-2009, 08:36 PM
InvaderTrax's Avatar
How'd you manage that? They're keyed so they only slide into the cam correctly, unless you put the rotor button on backwards, which can happen on the older ones that aren't keyed
Old 04-04-2009, 06:16 PM
G2IntegraGS's Avatar
You sure you have the firing order correct? Dont forget that cyl 1 is furtest from the dizzy.
Poedogg
10-03-2017 07:38 PM
96Formula6spd
03-04-2011 08:58 PM
egtony
10
09-04-2009 01:44 PM
the king.
06-27-2008 11:36 AM
drifterX420
07-11-2007 12:47 PM
Quick Reply: H23 wont start/replaced head gasket? Help
