CEL code 80?
Old Mar 15, 2009 | 05:12 PM
Kronn 98SH's Avatar
Default CEL code 80?
OK, important info. I replaced the thermostat and the oil pressure sensor on my ATTS unit two weeks ago. Since then, the ATTS light has been coming on intermittently. Today, the CEL came on when I started the car. I drove to AutoWeDontKnowShítZone to have the code pulled. Their unit received no info from my OBDII port. They suggested I have a wiring or fuse problem. So I jumped the blue connector and CEL blinks 80, ATTS blinks 4 or more different codes, and ABS blinks 3 or more different codes. Car is running a bit rough, very slight, but I have faint ticking noise at idle. No, it's not a bomb. I know my throwout bearing is shot (I made the mistake of using aftermarket instead of Honda and it died within a month of installation). Car has <105k miles. A month and a half ago I got a code for my EGR (P0116, Coolant Temp, CKT performance). I reset the ECU and it never came back. My OBDII port worked fine obviously. Since that time, I installed the header and VAFC-II, and dyno-tuned it.
Mods are:
VAFC-II w/ PnP harness
Hytech replica header
Carsound highflow cat
O2 simulator
Custom 2.5" exhaust
Car is lowered about 1" on GCs.
Anyone familiar with code 80 or know a site with the codes listed? Obviously I've looked but only found the OBDII codes.
Old Mar 15, 2009 | 06:21 PM
GraphiteMW's Avatar
Default Re: CEL code 80?
cel 80 is egr
Old Mar 15, 2009 | 09:24 PM
92SR4WS's Avatar
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
I'm not sure where it is originally from...
Old Mar 15, 2009 | 09:41 PM
Kronn 98SH's Avatar
^^^ That should be in the FAQ.
Old Mar 16, 2009 | 09:12 AM
gstrudler's Avatar
abs codes are stored until they are reset (resetting the ecu does NOT reset abs codes), so that could have been from whenever and is probably not pertinent if your abs light is not on. atts codes will not come through the obd port because they are not part of the obd standard nor are they stored in the ecu. knowing the codes the atts is throwing would be very helpful; unfortunately you have to sit and count and the blinks. my guess is you'll see codes 78 and/or 79 if you're seeing multiple codes, but knowing the others will help the troubleshooting process.
Old Mar 16, 2009 | 06:42 PM
Remiss's Avatar
x2 i was looking for that the other day
if its just the egr cleaning it should remove the cel
Old Mar 16, 2009 | 10:31 PM
Kronn 98SH's Avatar
Resetting the ECU removed the CEL. But I do intend on cleaning it soon.
Dead CIVIC
Jul 28, 2009 07:17 PM
Darkane
Jun 18, 2008 07:21 AM
snatch
Dec 17, 2004 11:13 AM
Nuts
Apr 22, 2004 05:24 AM
