electronic vtec switch
Old Mar 10, 2009 | 09:17 PM
BrizzlEK's Avatar
Default electronic vtec switch
i have a jdm h22A and the CEL flashed for the egr and vtec switch, the egr i am chasing down but what do i do to fix the switch
Old Mar 10, 2009 | 10:46 PM
MLBZ521's Avatar
Default Re: electronic vtec switch
Is the VTEC Switch Wired? Is it Broken? Does VTEC Engage?
Fix the EGR, sometimes one component can disable another resulting in a second CEL.
Old Mar 12, 2009 | 04:13 PM
BrizzlEK's Avatar
vtec engages in first but in anyother gear it wont, i can only audibly hear it, i bought the car swapped but i was told it was an o2 sensor that was setting it off, out of curiosity i ran the code and voila. vtec is wired, i am playing with the vaccum lines to the egr atm
Old Mar 12, 2009 | 04:14 PM
A Blue Lude's Avatar
Are you using a US ECU with a JDM VTEC solenoid?
Old Mar 12, 2009 | 06:16 PM
BrizzlEK's Avatar
i think its a jdm ecu, the guy said he used the ecu that came with the motor, its a jdm h22a, how can i tell if the vtec solenoid is jdm or usdm?
Old Mar 12, 2009 | 07:32 PM
USDM has an oil pressure sensor on it, JDM doesn't.
Old Mar 14, 2009 | 06:51 PM
BrizzlEK's Avatar
where is the switch? i cant find a chilton/haynes for the car all help is appreciated.
Old Apr 1, 2009 | 06:02 PM
vinuneuro's Avatar
Here you go. Factory service manual:
http://www.spoonhonda.com/Free_Downl...uals_s/119.htm
Old Apr 1, 2009 | 09:10 PM
BrizzlEK's Avatar
YOU WIN!!!! thank you
Old Apr 2, 2009 | 06:11 AM
Acidcrakker's Avatar
The EGR will not affect Vtec engagement on a stock ECU. Same thing with O2 system. You can throw codes for the EGR and o2 and your vtec will still engage.
GraphiteMW
Mar 18, 2009 10:11 AM
tankizk
Aug 19, 2007 08:51 PM
LeftCorner
Oct 1, 2003 03:42 AM
VTECVillain
Jan 30, 2003 04:20 AM
