Bleeding the clutch?
Old Mar 22, 2009 | 03:23 PM
big_az's Avatar
Icon3 Bleeding the clutch?
i got a 91 honda prelude 2.0si
it feels like theres alot of air in my clutch line
is there anyway i could bleed the clutch?
Old Mar 22, 2009 | 03:25 PM
big_az's Avatar
Default Re: Bleeding the clutch?
i have 1 more problem, my car burns about 2 qts. of oil a WEEK..
i checked the pcv valve and it seems to be good, but i seriously need some help with this prob to, it leaks really dark oil, it looks burnt
Old Mar 22, 2009 | 03:41 PM
NightCat's Avatar
oil burning could be your valve stems
Old Mar 22, 2009 | 06:51 PM
98SGH's Avatar
I would figure a 91 would have a cable tranny? well there is a bleeder valve on the slave cylinder on the tranny that you can loosen after depressing and holding the clutch pedal down and then retighten the bleeder and pull the clutch pedal back up; repeat as necessary
Old Mar 22, 2009 | 07:25 PM
big_az's Avatar
so basically it would have to be bled from the slave?
Old Mar 23, 2009 | 01:54 AM
SnlpeR's Avatar
it has to be bled by the slave
and thats not the proper way to bleed the line
attach hose from slave nipple into a bottle with some brake fluid in it..
make sure the hose is submerged into the fluid in the bottle
loosen bleeder valve on slave
pump clutch pedal a few times making sure not to empty the clutch master reservoir
refill reservoir as needed
on the last pump..leave the pedal down...then tighten the bleeder valve
pull back the pedal and make sure you have enough fluid in the res
dc2LS
Oct 16, 2010 04:56 PM
hondaless
Apr 2, 2009 08:58 AM
924doorEG
Jul 16, 2007 05:31 AM
AccordOn18z
Jul 7, 2006 02:57 PM
theoverachiever
Jul 7, 2002 10:47 AM
