Time for my H23vtec build
Moderator
so I have finally been researching and looking and have finally got 99% percent of my parts and decided I want to start my build. it was a present to myself for getting out the army after 6 yrs.i was going to do an h22 build but my engine builder said why not try to do h23 vtec and and see what you can do out of it. so i said f--- it lets get this going. my goal is 240-250 and 190 tq. i will see what happens.its going into my 4th gen prelude sivtec. possible compression is going to be 12.5 to 1 on 93 octane.
head
h22a (hot street package from CCCYLINDERHEADS
euro r im port match to the tb ( ROSKO built)
rdx injectors with fuel rail (from ROSKO also)
crower stage 3 cams
sk2 adjustable cam gears
titatitum springs + retainers (JGE)
flat valves (JGE)
68mm tb (s2000 style)
walboro fuel pump
arp head bolts
block
h23a1 block
h23a1 crank balanced and polished
h23a1 rods
type s pistons std
honda oem pistons rings
acl bearings
11.5 lb flywheel (lsd motorsports)
6 sprung street strip clutch kit (lsd motorsports)
new oem water pump
new oem oil pump
balance shaft elimantor kit (kaizenspeed)
manual tensioner replacement kit
honda oem belts
bisimoto custom header (on the way last part missing)
oem honda head gasket
tranny
h22a
obx lsd tranny
stock gear ratio i drive on the highways alot so need some driveability.
dss axles level 1
I should be getting my head back from steve sometime this week or next. would have been earlier but poor guy got a flu. i am probably going to go to xenocron for tuning ectune most likely. getting the block cleaned at the machine shop should be here next week. hopefully I can be ready for honda day in april but will be close. I will have pics soon next couple of days hopefully!!! let me know what you guys think! the reason for people names in caps is thanking them for all the help they have given me...!!!!!!!
head
crower stage 3 cams
flat valves (JGE)
walboro fuel pump
arp head bolts
block
h23a1 block
h23a1 rods
type s pistons std
acl bearings
new oem water pump
new oem oil pump
honda oem belts
tranny
h22a
obx lsd tranny
dss axles level 1
Last edited by vinuneuro; 03-23-2009 at 06:06 AM. Reason: Capitilize title words properly
Re: TiMe FoR mY H23 vTeC bUiLd Dd
Looks like a nice build, I just did mine and is burning a lot of oil, like a quart per every 150highway miles more less. let me know if you have the same problem during break in period. Get them pics soon man!!
Moderator
Hows the OBX lsd tranny perform? Usually a quality and function issue with most OBX products.
Would OEM axles not be an option?
Good to see your balancing the crank from the h23, is that pretty much all you need to balance to allow the h23 to rev a bit higher?
OP: I'm not a fan really of the crower 3s, sorry to rain on your parade and such, but I don't think you'll be seeing 240whp with them. But who knows, they might respond much better to your setup than others.
I didn't have good success with them but that was on stock internals.
that build doesn't look like it will make it. maybe something like 220whp.
you are better off going with some skunk pro2's then the crower stage 3.
Moderator
well my little brother used it in his single cam turbo with and it was 386 tq and it was good for him.
the problem i have is that i break axles easy. i broke on my stock h22 3 axles already.
Moderator
It surely can't hurt, but the reason the h23 crank doesn't like to rev higher is simply the fact that it has a longer stroke.
I'm glad i just went H23a VTEC out of the SiR accord wagon to begin with, this looks like alot of work lol. Good Luck!
moderator emeritus
btw, dont set power goals. They are worthless unless you know what you have ran on that dyno before and tend to break hearts unless you are turbo and can just turn up the boost to fit your ego.
good luck.
moderator emeritus
Moderator
Moderator
i hear what you saying thats why i am also care about getting into the 13's with this setup... maybe like urs and rosko
moderator emeritus
shouldnt be a problem. Dont worry about HP power. Thats just for people to brag. I would rather have 180whp and run a higher trap than someone with 210whp. THAT is bragging rights against people who think HP wins races.
just be sure to get street tuning and dyno tuning. You will need it.
Moderator
Moderator
got pics of some parts. i just fun out that the block is good to go and i should be picking it up in a few days. crank was balanced and block was cleaned and leveled. the pistons where taken care off into the rods. hopefully i get the head this week cause i want to start putting all the stuff together.what sucks is that when i was putting the mainfold together i am missing a freaking rdx clip and i don't know where it is. i've seen that u can use the scion mod but i was seeing if anyone knows where i can get the clip?????? it sucks that i have all this stuff and nowi missing a freaking clip.
Moderator
Re: Time for my H23vtec build
the only good thing this week was that i was able to get some high grade steel braid hose from my job that we are getting rid off. since i work on helicopters we have a good amount of it left and its good for 1500 psi just buy fittings for the proper spots still wondering if i should do a catch can???
Looks good so far. Is that flywheel an OEM one that's been machined, or is it cut from fresh stock? Good luck with the build.
Nice build up so far... cant wait to see it when its done. What ecu are you gunna run and how much is the Bisi Header guna set you back?
