Problems with 91 Prelude
Old Mar 23, 2009 | 09:49 PM
nhs1986's Avatar
New User
Default Problems with 91 Prelude
Hey.
Having problems with a 1991 Honda Prelude, Was driving it and it started to rev real low and then the engine just cut out. It will not start anymore. It has petrol, and oil and the battery has power. It just doesnt want to start. Any ideas would be a big help,
Thanks.
Old Mar 23, 2009 | 10:03 PM
dtapia's Avatar
Default Re: Problems with 91 Prelude
ok can you give more details. does it turn over fast does it have spark is the check engine light on ?
Old Mar 23, 2009 | 10:35 PM
nhs1986's Avatar
New User
It seems to be turning over okay, just wont start up. Maybe a little fast. The check engine light is off, but in the past when driving has come on. Is there an easy way I can check the spark?
Old Mar 24, 2009 | 07:24 PM
nhs1986's Avatar
New User
I have changed over the spark plugs with new ones, there was petrol on one of the plugs, and all look woren out, still not starting tho.
I am going to try jump start it, but I am pretty sure it isn't the battery.
Old Mar 25, 2009 | 02:41 PM
queensplazasouth's Avatar
New User
I would start with the fuel pump. Have someone hit the tank with a rubber mallet while you crank the engine.
To check for spark, take out a plug, plug it into the wire, lay the plug on a metal part of the engine, and crank the engine, you should see spark.
If no spark check cap, rotor, coil. Visually inspect the wires for physical damage, especially the one connecting the coil to the distributor (if the coil is on the outside of the distributor, some cars have it inside, not sure about yours)
Check engine light should be on with the key on engine off, if not you may have a faulty computer.
Old Mar 25, 2009 | 08:16 PM
Toda_Lude's Avatar
New User
sure its not your starter?
Old Mar 25, 2009 | 08:17 PM
Toda_Lude's Avatar
New User
fuel pump on mine is going to be my next upgrade i hate when those things start to go
Junior_rigo
Apr 23, 2015 07:50 AM
SLOSI7
Jun 19, 2008 06:31 PM
tlkm4
Jun 30, 2004 08:30 AM
sirb18a
Feb 4, 2004 10:44 AM
