Hood help?
Old Mar 25, 2009 | 07:25 PM
h22lude317's Avatar
Default Hood help?
i have a 92 s model of the lude
My hood wont lock down to the hood latch
this is my second hood latch but i got it from a junk yard it seems fine
brand new oem hood
I dont want anything to happen to my motor can anyone help?
Old Mar 25, 2009 | 11:17 PM
amalby's Avatar
Default Re: Hood help?
does it not even line up with the latch?
Old Mar 26, 2009 | 03:57 PM
h22lude317's Avatar
it lines up with it but it doesnt go in far enough to lock i guess
Old Mar 26, 2009 | 04:43 PM
bluedlude's Avatar
the latch is mounted with three bolts. loosen them up and move the latch up a little bit. then it should engage.
Old Mar 26, 2009 | 04:57 PM
h22lude317's Avatar
i'll try that tomorrow, thank you very much.
Old Mar 26, 2009 | 07:02 PM
Krusty_the's Avatar
Huh, I suffer from the same thing. Just the 3 bolts and it goes up and lines back up? Is it from closing the hood to hard I wonder? I thought it was front/back alignment.
Old Mar 27, 2009 | 03:45 AM
bluedlude's Avatar
you will have to play with it to get it lined up perfectly. you should never let the hood slam shut. just set it down and push it closed.
Old Mar 27, 2009 | 09:44 AM
h22lude317's Avatar
Got it to lock
thank you bluedlude
Old Apr 2, 2009 | 08:59 AM
Remiss's Avatar
i had the same problem till i wrap the hook that goes into the latch with electrical tape
fixed the problem quite well really
02_Si_FTW
14
Mar 27, 2008 09:03 AM
burnt_clutch
Jan 24, 2007 07:14 PM
2fast4udude
Mar 5, 2006 03:43 PM
Soda Popinski
Oct 19, 2005 06:34 PM
7808
May 18, 2004 12:42 AM
