::The official Type SH performance thread::
Old Mar 17, 2009 | 06:49 PM
falcon548's Avatar
Default ::The official Type SH performance thread::
just throwin this out there since i didnt find it in the FAQ...im looking at realistically modifying my h22a4 in my type SH and wanted to know what the deal is if i wanted to keep ATTS. Id also like to see some dynos and 1/4 mile times of some SH's and people with personal experience in modifying their SH.
Old Mar 17, 2009 | 10:32 PM
Kronn 98SH's Avatar
Default Re: ::The official type SH performance thread::
http://preludepower.com/forums/showthread.php?t=310117
That will get you started.
My Mods:
Generic CAI w/ K&N filter
Hytech replica header
Custom 2.5" exhaust w/ Magnaflow high-flow cat
Denso O2 sensors w/ O2 simulator
NGK Iridium plugs
10.2mm plug wires
VAFC-II
New radiator w/ blue OBX hoses
JDM top hats & strut bar
KYB AGX struts
Ground Control coilovers
Cross-drilled & slotted rotors
Raybestos ceramic brake pads
audio system
My results:
173whp/140tq
14.9ish ¼mi times
Mods to come:
stage 1 clutch
lightweight flywheel
Traction bar
Aftermarket or modified intake manifold
S2K throttle body
lightweight 7.5" rims
better tires
stiffer springs
cams & cam gears
pistons
Greddy eManage
Old Mar 18, 2009 | 05:47 AM
Quan_97SH's Avatar
My Mods:
NGK Iridium plugs
10.2mm plug wires
VAFC-II
KYB AGX struts
audio system
My results:
173whp/140tq
14.9ish ¼mi times
How do you normally drive? my car is my daily driver so i spend most of my time in the 3K to 5K rpm range. But looking at the dyno graphs for the simple bolt-on mods like cai and header, the power/torque gain are in the higher rpm range. so i won't see much of those gains.
Is there anything that would shift the power gain to the lower rpm range?
Old Mar 18, 2009 | 08:48 AM
ceezo70's Avatar
yea bro there's not much u can do without messing up the ATTS...just your simple bolts ons, CAI, HEADER,2.5 Exhaust, greddy emanage, maybe the type s cams, S2K throttle body, Iradium plugs and wires...pretty much it and have fun with the handling...
You looking for more agrressive power i'd say get a base model..
Old Mar 18, 2009 | 11:21 AM
gstrudler's Avatar
I think this thread will be more productive if people list what they know causes problems on an SH, not what works. I'm pretty sure there are people running low boost setups that maintain ATTS functionality, not sure about n2o, and many of us are n/a. There are obviously many things that will work, but only a few that won't.
The big one I know off-hand is no OBD1, no chips, etc. However, I'm curious if anyone has tried running parallel ecu's before (I'm guessing not). I don't know this for a fact, but I'm guessing no changing gear ratios (including fd).
Big question for me right now is if anyone has tried stroking an SH before. I'm contemplating rebuilding the bottom end with crank & rods from an f22, but not sure if this will wreak havoc on the atts controller.
Old Mar 18, 2009 | 12:25 PM
Kronn 98SH's Avatar
Using VAFC to lean out the A/F and drop VTEC a little lower would give you power in that range. Also, I'm researching a way to modify the butterflies in the IM to get some more 4k-5k power.
Old Mar 18, 2009 | 03:32 PM
falcon548's Avatar
lol that, too, is my thread...on allprelude forums im brlude161 so anyway...
my mods include
an aluminum radiator
rotors, calipers etc
OEM internals redone at around 100,000
dc headers
dc exhaust
dc struts and strut bar
skunk 2 coilovers
stage2 clutch
and more...
but im not seeing the power that u seem to be...i lost to a single cam 4th gen FTL, although i am a new driver it seemed he had the advantage in weight and driving.
i read all about the euroR intake manifold and all the custom plates and mounts needed or whatever and im not looking for that much of a pain in the ***...also what is a greddy eManage?
Old Mar 18, 2009 | 04:08 PM
Kronn 98SH's Avatar
my mods include
dc headers
dc exhaust
skunk 2 coilovers
stage2 clutch
and more...
Your main problem is that DC junk you have installed. Replace the header and exhaust for what I have. Greddy eManage is the only ATTS-friendly tune you can get.
Old Mar 18, 2009 | 04:43 PM
falcon548's Avatar
it was bought with the dc junk but its not worth a replace...i may throw a msd digital 6 in there and take out my cruise control
Old Mar 18, 2009 | 07:45 PM
gstrudler's Avatar
my mods include
dc headers
dc exhaust
skunk 2 coilovers
stage2 clutch
and more...
the only thing I see in that list that might be getting you any power is the dc exhaust & maybe 1 or 2 points with the header. you don't have any other power mods installed, so I'm not sure what you're expecting. and yes, 4th gens are lighter by about 200lbs over the SH, so you're already at a significant disadvantage in that case.
Old Mar 31, 2009 | 06:34 AM
Redludesh00's Avatar
Im looking in to the greddy emanage does anyone know if it will control my atts, I want to retain the atts working. But I want to know from some one that has actually done it and not what theyve heard.
Old Mar 31, 2009 | 09:46 AM
Kronn 98SH's Avatar
Greddy eManage and AEM F/IC do not disable ATTS, but they don't "control" it either.
Old Mar 31, 2009 | 01:16 PM
mizlude's Avatar
I know if you go over the 250whp range with atts it will fail. If your looking for the most power out if it just slap on a jackson racing super charger with i/h/e that will be about as much power as you can get before the atts will go haywire.
Old Mar 31, 2009 | 01:28 PM
mattsnooz's Avatar
my mods include
dc headers
dc exhaust
skunk 2 coilovers
stage2 clutch
Theres very little performance work done on your car. Your lucky if your pushing 160 whp. That dc stuff is probably a hindrance on your exhaust given the typical decent efficiency of the h22 stock header (h23a1 header is a different story, any aftermarket header is an improvement).
awood202
Mid-Atlantic (Sales)
Sep 26, 2012 11:14 AM
88hatchef
Nov 30, 2006 01:53 PM
DarkBB4
Nov 10, 2005 06:48 PM
B2FiNiTY
Oct 18, 2001 09:58 PM
