cluster problems
Old Mar 23, 2009 | 11:49 AM
gonzo_b16's Avatar
Icon2 cluster problems
hi, I have 91 honda prelude si with a problem.
and my friend said that I should ask honda tech.
the problem is that the gauges wont light up.
all the highbeam, low fuel, etc indicators work but the light wont turn on for the speedo,tach, and fuel.
would that mean that
those bulbs are out...or
a fuse is blown.
or something im not getting.
and I checked the fuses with a tester and they all worked. unless i did it wrong.
and I took the cluster out and checked the bulbs and they all seemed to be in good condition.
just wondering if i could get some help because the gauges are pitch black at night and I cant see anything
Old Mar 23, 2009 | 12:22 PM
Kronn 98SH's Avatar
Default Re: cluster problems
bad switch, bad relay.
Old Mar 23, 2009 | 03:18 PM
gonzo_b16's Avatar
hm, how would I go about fixing that...
Old Mar 23, 2009 | 04:07 PM
Kronn 98SH's Avatar
First, you have to determine the problem. Then, replace the faulty piece.
Old Mar 23, 2009 | 10:01 PM
gonzo_b16's Avatar
well what would be the problem in my case....
the fuses all work....the bulbs arent burned out
im not sure what a bad switch means and/or a bad relay.
the highbeam, ebrake, cel, low fuel, seatbelt they all work.
maybe i missed a bulb.
Old Mar 23, 2009 | 10:05 PM
Kronn 98SH's Avatar
Switch = the thing that you use to turn **** on, just like a light switch in a house.
Relay = little electrical box thing, not a race
I don't believe all 3 gauges are lit by a single bulb, so chances of it being a bulb would be slim. You don't sound like you know electrical, so your best bet would be to take the car to an automotive electrician and let them figure it out. Should be pretty simple.
Old Mar 23, 2009 | 10:07 PM
gonzo_b16's Avatar
yeah, that seems like the best solution for me.
thanks.
theorigkav3
Oct 26, 2010 04:50 PM
blackmugensivic
Dec 27, 2008 06:19 PM
trrbl1bmx
14
Jul 10, 2006 07:50 PM
jdm82
Mar 4, 2006 05:51 PM
mylhigh469
Sep 24, 2004 02:50 PM
