Doing a Compression test: NEED HELP QUICK
Old May 13, 2003 | 07:44 AM
Toda Built's Avatar
Default Doing a Compression test: NEED HELP QUICK
Ok, this is my first time even trying this so I have a couple of questions. I have taken out all the spark plugs and disconnected the wires that go to the distributer cap. Then I followed the intructions on the compression tester box and It said to disconnect the high tension lead from the distributer. Do I ground this to something?
Next It says insert compression tester and manually crank the engine over at least 4 cranks. How the hell do I manually crank over the engine?? Do I use the key like normal or is there some other way.???
Old May 13, 2003 | 07:49 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Doing a Compression test: NEED HELP QUICK (SH_LUDER)
turn the key like you are starting it, push the gas pedal to the floor toy open the secondaries to get a correct reading
Old May 13, 2003 | 07:51 AM
Toda Built's Avatar
Default Re: Doing a Compression test: NEED HELP QUICK (Boosted97Lude)
thanks man.....
Do I need to ground the high tension lead from the distributer? I shouldnt just let it hang there should I?
Old May 13, 2003 | 07:58 AM
Boostless97Lude
Guest
Posts: n/a
just pull the spark wire loose from the igntion coil
Old May 13, 2003 | 08:04 AM
Toda Built's Avatar
Alright... I just finished the test on all the cyl. and I came up with 210 all the way across the board.
Isnt that rather Low? I was told they should read near 220-230
Old May 13, 2003 | 03:32 PM
LudeyKrus's Avatar
those are great numbers; 10 psi's not really much to worry about
Old May 13, 2003 | 03:40 PM
KrazE's Avatar
Default Re: Doing a Compression test: NEED HELP QUICK (LudeyKrus)
When doing a compression test, when do do stop turning the key?
I heard 5 cranks, but i also heard till the psi doesn't move anymore. Which is right?
Old May 13, 2003 | 04:20 PM
Toda Built's Avatar
Default Re: Doing a Compression test: NEED HELP QUICK (KrazE)
well the directions on the tester box said at LEAST 4 cranks or until the psi guage stops going up
Old May 13, 2003 | 04:42 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH_LUDER &raquo;</TD></TR><TR><TD CLASS="quote">
Do I need to ground the high tension lead from the distributer? I shouldnt just let it hang there should I?</TD></TR></TABLE>
Yes you need to ground it or you run the risk of frying your coil. It's easier to just pull the ECU fuse to disable the ignition and fuel sustems.
TUR3Ovtec
Oct 17, 2013 02:41 AM
Historyg
Oct 25, 2007 03:40 AM
zracer240
Apr 24, 2005 08:35 AM
5thgenlude101
Sep 17, 2003 02:40 AM
JCracer723
Aug 22, 2002 03:17 PM
