Tons of coolant pressure....why?
Old May 7, 2003 | 11:13 AM
spoolinlude's Avatar
I live under a rock
Default Tons of coolant pressure....why?
Alright, I bought a new radiator from C&R racing for the 4th gen turbo that most of you should know i have by now, anyway, i replaced the thermostat this morning and put the radiator, bled all the air out and did everything right. Now i have tons and tons of pressure in my coolant lines and the brand new radiator is smoking out pressure like crazy....i can't figure out what else it could be, the old radiator popped under the pressure, i just figured it couldn't handle it.....but its still tons of pressure, the headgasket is new, no coolant in the oil or ne theing like that.....wtf else could it be????
Old May 7, 2003 | 11:17 AM
Stew Pidasso's Avatar
Default Re: Tons of coolant pressure....why? (spoolinlude)
Is the thermostat in backwards? It sounds like a blockage somewhere to me.
Old May 7, 2003 | 11:22 AM
BoostedH23a1's Avatar
Default Re: Tons of coolant pressure....why? (Stew Pidasso)
can u even put one in backwards??
Old May 7, 2003 | 12:17 PM
577HondaPrelude's Avatar
Try this: After the car is cool, take off the radiator cap, start the car up, let it warm up a bit, then look down into the radiator. See if you can see the coolant flowing (pumping) though. If the coolant is not flowing or just flowing out of the cap, then something is likely clogged up.
Old May 7, 2003 | 05:10 PM
clendaniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I bought a new radiator from C&R racing for the 4th gen turbo that most of you should know i have by now, anyway, i replaced the thermostat this morning and put the radiator, bled all the air out and did everything right. Now i have tons and tons of pressure in my coolant lines and the brand new radiator is smoking out pressure like crazy....i can't figure out what else it could be, the old radiator popped under the pressure, i just figured it couldn't handle it.....but its still tons of pressure, the headgasket is new, no coolant in the oil or ne theing like that.....wtf else could it be????</TD></TR></TABLE>
It's a leaky headgasket...does it only pressurize after you boost on it? I had similar issues before ARP had a head stud set for the h motors. You won't get any mixing as the cooling system is only pressurized when combustion gases leak into the cooling jacket, the leak's not bad enough for coolant and oil to mix. I went through a couple headgaskets and ended up cracking the stock rad...ended up with a fluidyne, ARP studs, and a cometic gasket.
--Ian
Old May 7, 2003 | 06:43 PM
I live under a rock
Default Re: Tons of coolant pressure....why? (clendaniel)
I already have the cometic head gasket thou... anyway... it looks like it may have cleared up on its own some how, like whatever blockage there was free-d up or something..... the hoses still have a lil more pressure than i would like, but i let it sit in the driveway with the AC on and it didn't over heat....and the hoses seemed ok....so I think m ok for now....lets hope anyway....i should probably replace those head bolts with the ARP's thou.......where can i get them?
Old May 7, 2003 | 06:49 PM
I live under a rock
Hey clendaniel, m local to you..... and I've heard about your prelude, I'd love to see it sometime, and I'll show you my setup too, did you do that upgrade to Toms supra yet? Hope your lude is running soon, i know you've had some problems... let me know
Steve
Soooogie
Sep 29, 2013 04:54 AM
civicsir94
May 20, 2008 03:21 AM
soon2bdropped
Jan 15, 2007 03:41 AM
Weston
29
Feb 5, 2005 06:59 PM
iwouldHITit
Jul 31, 2003 05:44 PM
