compression equation
Old May 11, 2003 | 11:08 AM
mhgleitz's Avatar
Default compression equation
what are the equations needed to calculate compression ratios?
Old May 11, 2003 | 11:40 AM
XLEntropy's Avatar
Default Re: compression equation (mhgleitz)
cylindrical volume equation? area of base time height. do it twice at bottom dead center and top dead center. then measure of volume at bdc over the measure of volume at tdc. i hope thats what ur asking for.
Old May 11, 2003 | 11:43 AM
JG Luder's Avatar
Default Re: compression equation (XLEntropy)
basically the head needs to come off, or you need to know the exact demensions of your pistons, and your head bowl, combined with what type of head gasket you have.
Old May 13, 2003 | 06:43 AM
flyrod's Avatar
These have been posted several times...
Old May 13, 2003 | 10:38 AM
str8rcn's Avatar
Default Re: compression equation (flyrod)
Are you trying to take compressoin test numbers (i.e. 215) and see what they convert to (i.e. 10.0:1)? If so i have a chart i can email you or to someone who can post pics.
Old May 13, 2003 | 11:03 AM
JG Luder's Avatar
Default Re: compression equation (str8rcn)
It wouldn't work as well as you think. Cause you still have to take into account leakdown, and other issues that make a compression test not 100% accurate.
Old May 13, 2003 | 11:09 AM
flyrod's Avatar
Default Re: compression equation (Lone Luder)
There are lots of threads on this. Here is one with some calculations:
https://honda-tech.com/zerothread?id=438456
Boostn B20
11
Nov 27, 2008 01:22 PM
zoom545
Nov 22, 2005 09:04 AM
bluedelsol
May 1, 2003 05:00 PM
aut0tek
Mar 18, 2003 11:00 AM
