Do performance spark plugs make a difference?
Old May 8, 2003 | 02:41 PM
CleanLIttleLude's Avatar
Default Do performance spark plugs make a difference?
What is the difference between regular spark plugs and performance ones?
Old May 8, 2003 | 02:49 PM
str8rcn's Avatar
Default Re: Do performance spark plugs make a difference? (CleanLIttleLude)
Stay with NGK's.Ive tried everything up to the Denso Iridiums and nothing made a noticeable difference."Performance Plugs" usually are made of a different material such as platinum or iridium.Yes these do last a bit longer and i think the denso iridium have proven to produce a whopping 1hp gain at a certain RPM.Definitely not worth the money.
Old May 8, 2003 | 02:54 PM
JG Luder's Avatar
Default Re: Do performance spark plugs make a difference? (str8rcn)
stick with the wide world of NGK's. They will handle all the Honda power you can throw at it.
I'll never run another set in my life unless given no choice (AKA, the middle of nowhere in the Gumball.)
Old May 8, 2003 | 02:57 PM
One Slow Lude's Avatar
Default Re: Do performance spark plugs make a difference? (Lone Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lone Luder &raquo;</TD></TR><TR><TD CLASS="quote">(AKA, the middle of nowhere in the Gumball.)</TD></TR></TABLE>
by the way, i havent been on in a little while, how did that go? did you guys post pics anywhere??
Old May 8, 2003 | 03:12 PM
GODluvsLUDES's Avatar
I just changed my plugs a couple days ago. I used Bosch platinum +2. They seemed to smooth the idle out and have a little better response on the throttle.
My .2
Old May 8, 2003 | 03:52 PM
rjr162's Avatar
Default Re: Do performance spark plugs make a difference? (GODluvsLUDES)
the platnuim and iridum are harder, hence the longer lasting, but being a harder metal it's going to actually decrease the spark's power. Just something to think about.
Old May 8, 2003 | 04:05 PM
Que_Lude's Avatar
I have the denso iridiums,,, I like them so far.
Old May 8, 2003 | 05:07 PM
Cottonwoodz's Avatar
I run copper NGK Vpower H23A1 plugs. ($1.80 a plug)
Why pay $11 for 1 platinum plug?
Old May 8, 2003 | 09:45 PM
h2392si's Avatar
Default Re: Do performance spark plugs make a difference? (Cottonwoodz)
im running bosch platinum 4 and ive had them over a year and ive never had a problem with them. i like them and ive tried the NGK ones and i like the bosch platinum better, just my 2 cents. Peace
Old May 8, 2003 | 09:49 PM
krnboixshawn's Avatar
Default Re: Do performance spark plugs make a difference? (h2392si)
how do u tell what spark plugs you have and where is it?
Old May 9, 2003 | 03:17 AM
incubus's Avatar
Default Re: Do performance spark plugs make a difference? (krnboixshawn)
you use a spark plug wrench to carefully remove your plugs from your head, the brand name and model are usually printed on the ceramic part just below the threads and seating.
Old May 9, 2003 | 05:30 AM
So the only real difference between the NGK platnum plugs and the copper ones is platnum will last longer?
Old May 9, 2003 | 01:16 PM
rjr162's Avatar
Default Re: (CleanLIttleLude)
yeap. Suppose to last "120,000" miles. But leave them in that long w/o ever atleast braking them loose and they'll be really good to try to get out at the 120,000 mile mark
Old May 9, 2003 | 01:28 PM
Xlerate9's Avatar
Default Re: (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">yeap. Suppose to last "120,000" miles. But leave them in that long w/o ever atleast braking them loose and they'll be really good to try to get out at the 120,000 mile mark</TD></TR></TABLE>
I agree.. that's why you should always put some anti-seize on them when you put them in... even if you only plan on leaving them in for 30k miles... you should still put a little on to be safe... it may make your life a lot easier when you go to change them.
Old May 9, 2003 | 01:46 PM
Greyout's Avatar
Default Re: (Xlerate9)
copper &gt; *
Old May 9, 2003 | 01:53 PM
I change mine every 6 months regardless of milage. .02
OneCrzySetup
Nov 17, 2006 11:53 AM
dragaholic
Dec 8, 2005 09:05 PM
Markov
Oct 7, 2005 10:33 AM
rice a roni
27
Dec 7, 2003 01:08 PM
Tobal
Jul 21, 2003 09:12 PM
