Alternator Problems
Old May 12, 2003 | 07:38 AM
iammrhand's Avatar
Default Alternator Problems
I have replaced my alternator 3 times in the last 4 years, and it looks like its going to be a 4th time here shortly. Currently, my alternator light only comes on when accelerating. Is there a wiring short or something going wrong here that I am overlooking?
Old May 12, 2003 | 09:13 AM
prelude1897's Avatar
Default Re: Alternator Problems (iammrhand)
Do you have your belts on there tight enough? You shouldn't be replacing your alternator that often. If you can, see if any wires are exposed or cut that lead to the alternator
Old May 12, 2003 | 09:18 AM
Elkins911's Avatar
Default Re: Alternator Problems (prelude1897)
i would take advantage on the lifetime warrenty ones. i just replaced mine.
Old May 12, 2003 | 10:15 AM
iammrhand's Avatar
The belts are tightened to specs. I tightened them a little bit extra to make sure. I noticed that there is a little bit of corrosion on the terminal B connector, could that be a problem? I do have a lifetime warranty on my alternator, but I'm getting sick of replacing the bastards!
Old May 12, 2003 | 10:53 AM
prelittlelude's Avatar
if you have gone thru 3 already then you either have a wiring problem from your alternator to your battery, or you have a short somewhere that is over loading your battery causing to much strain on the alternator, though i doubt that since your car would be dead everytime you went to start it
EJ8_Man
May 25, 2019 10:21 PM
deathdillan
Apr 28, 2014 02:03 PM
92silude
Mar 14, 2005 09:29 AM
