Turbo problems .....please help
Old Jun 16, 2003 | 06:13 PM
black_sh's Avatar
Default Turbo problems .....please help
Dear fellow turbo luders,
i have a 2001 prelude sh and just recently installed a garret t3 60-1 turbo with a hondata s200b. my problem is that i could rev my motor at idle to redline, but when i boost...i can't go past 5000 rpm. does anyone know what this problem might be? any help would be greatly appreciated.
Old Jun 16, 2003 | 06:22 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Turbo problems .....please help (black_sh)
have you posted anything in the FI forum???
what MAP sensor are you using?
Old Jun 17, 2003 | 02:52 PM
black_sh's Avatar
Default Re: Turbo problems .....please help (Boosted97Lude)
well, i haven't posted in FI b/c i've tried many times awhile back and never get any help. i'm running on a stock map sensor at around 6 pounds of boost. i don't know what the problem could be.
Old Jun 17, 2003 | 04:31 PM
black_sh's Avatar
not sure if it will help, but i'm using a p28 ecu with the hondata
Old Jun 17, 2003 | 04:33 PM
Boostless97Lude
Guest
Posts: n/a
well, your secondaries aren't opening for one thing, that might cause a problem
Old Jun 17, 2003 | 04:40 PM
poison's Avatar
Sounds to me like your Secondary Butterflies are closed and when opened, all of the boost is going in.
Try hooking up your IAB's to this and keep us posted on how it works:
Old Jun 17, 2003 | 04:45 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Turbo problems .....please help (poison)
what does that accomplish? does it just leave them open al the time??
Old Jun 17, 2003 | 04:50 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">what does that accomplish? does it just leave them open al the time?? </TD></TR></TABLE>
Nope. It will be closed at idle, and at mid throttle. But open at mild to WOT.
They just open according to the throttle position.
Little nice thing I got when swapping the lil beast into the EG
Old Jun 17, 2003 | 04:52 PM
Boostless97Lude
Guest
Posts: n/a
whoa, that's like WOT time TWO!!!!!
lol, re-arrange the letter in WOT and you get TWO
Old Jun 17, 2003 | 04:54 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">whoa, that's like WOT time TWO!!!!!
lol, re-arrange the letter in WOT and you get TWO</TD></TR></TABLE>
Whoa.....Sam is TWO times the WOT creative!
Old Jun 17, 2003 | 05:46 PM
black_sh's Avatar
actually the secondary butterflies were already removed b/c the p28 doesn't control secondary butterflies.
Old Jun 17, 2003 | 05:52 PM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_sh &raquo;</TD></TR><TR><TD CLASS="quote">... b/c the p28 doesn't control secondary butterflies.</TD></TR></TABLE>no sh*t.... that was exactly our point
ask the question in the FI forum, b/c apparently no one knows here, i use AEM EMS myself
Old Jun 17, 2003 | 06:51 PM
PrecisionH23a's Avatar
Is the light on the interface box flashing or solid? (at idle and at 6k) Are you throwing a CEL? If you were experiencing it at 3200 i would tell you that is the limp mode rev limit. In that case, the problem would be the rom, ecu, or socketing.
Old Jun 17, 2003 | 07:18 PM
black_sh's Avatar
"no sh*t.... that was exactly our point"
geesh, didn't mean to say anything to offend you. i just wanted to let you know that the butterflies weren't the problem b/c i had removed them already b/c i knew that the p28 didn't control secondaries.
Gude,
i'm not getting a check engine light.......hmmm
Old Jun 17, 2003 | 07:25 PM
Boostless97Lude
Guest
Posts: n/a
well, i'm stumped then, i;d have to actually drive the car or some **** now to see for myself
Old Jun 17, 2003 | 07:27 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_sh &raquo;</TD></TR><TR><TD CLASS="quote">"no sh*t.... that was exactly our point"
Gude,
No CEL at all? Can you rev past 5000 when the car is in neutral?
Old Jun 17, 2003 | 07:31 PM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote"> Can you rev past 5000 when the car is in neutral?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_sh &raquo;</TD></TR><TR><TD CLASS="quote"> i could rev my motor at idle to redline, but when i boost...i can't go past 5000 rpm. .</TD></TR></TABLE>
reading comprehension OWNZ!!!!!!
Old Jun 17, 2003 | 07:36 PM
poison's Avatar
Oh heyall no.
When you hit 5000, does it just cut off, or bounce on it? Sounds to me like you are being thrown in limp mode on the ECU. But I don't know much about Hondata.
Old Jun 17, 2003 | 07:58 PM
Default Re: Turbo problems .....please help (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">Is the light on the interface box flashing or solid? (at idle and at 6k) Are you throwing a CEL? If you were experiencing it at 3200 i would tell you that is the limp mode rev limit. In that case, the problem would be the rom, ecu, or socketing.</TD></TR></TABLE>
you never answered my questions except for the CEL. i cannot diagnose your problem unless you let me know.
Old Jun 17, 2003 | 08:46 PM
black_sh's Avatar
when i hit 5000 it doesn't cut off....it bounces off the rev limiter. Gude, i believe the light is solid. i will have to check again tomorrow and let you know. thanks for helping me try to diagnose this problem.
Old Jun 17, 2003 | 10:04 PM
flip1199's Avatar
did u install the 3step rev limiter??
Old Jun 18, 2003 | 07:06 AM
Firedrake's Avatar
Default Re: Turbo problems .....please help (flip1199)
It sounds like something with your limiters is messed up....who tuned the car for you?
Brian
Old Jun 18, 2003 | 10:01 AM
black_sh's Avatar
Default Re: Turbo problems .....please help (Firedrake)
person who tuned my car is one of my good friends. he's been tuning with hondata for years and never had problems on any car but mine. also, i don't have the 3-step rev limiter option
Old Jun 18, 2003 | 03:46 PM
MuGeN_PreLuDe's Avatar
dam turbo'n a prelude sounds like a bitch.. im having second thoughts.. unless somone teaches me exactly every single thing to know about installing a turbokit for my prelude -_-''
Old Jun 18, 2003 | 06:34 PM
black_sh's Avatar
Gude,
i double checked today, the light on the interface is not blinking. it's solid
