Suspension Dilema
Old Jun 19, 2003 | 11:32 PM
501 Lude's Avatar
Default Suspension Dilema
I'm not sure if i want to drop my car using coilovers or springs. I'm wanting about a 1 inch drop so would it be ok to use the coilovers to only drop about an inch or should i just get sport springs. Also where could i find good prices on Ground Controls and H&R sport spings + Eibach Prokit.
Old Jun 20, 2003 | 05:07 AM
rjr162's Avatar
Default Re: Suspension Dilema (501 Lude)
if you're not going to adjust the ride height just go for a good set of springs and shocks. If you think you might want to adjust the ride height, then get the coil-overs and a good set of shocks. Your ride will end up feeling the same either way.
EDIT> they will feel the same if you have the same shocks in each setup, plus springs with nearly identical rates, etc
m.glisson003
Suspension & Brakes
Aug 6, 2011 01:49 PM
TwitchDa9
Mar 22, 2011 05:33 AM
messeduprex
14
Apr 10, 2007 11:06 AM
GetSmoked
Feb 17, 2005 03:53 PM
ieatrice
Jan 29, 2004 09:54 PM
