help on h23
Old Jun 20, 2003 | 02:10 PM
goula SOS's Avatar
From: Kills Official Truck Quality Assurance Manager, USA
Default help on h23
I read the post on going all motor on the H- series got a few ideas but I have a question I want to run mid 14's on an all motor h23 what do I need to do? thanks
Old Jun 20, 2003 | 02:20 PM
flip1199's Avatar
Default Re: help on h23 (goulasos)
if this is goin in a hx then you should get some jdm h22 pistons or even type s pistons along with i/h/e/gears/afc. that should put u around mid 14's
Old Jun 20, 2003 | 02:52 PM
LudeyKrus's Avatar
Default Re: help on h23 (flip1199)
i'm pretty darn sure the type-s pistons won't work in the H23; i'm droppin in USDM H22's in my H23 right now; i'll let you know how it comes out. The JDM H22's should put your compression ratio to about 11.5:1, which i think would be the most you would really wanna go for a street car.
Old Jun 20, 2003 | 03:57 PM
hondasnmyblud's Avatar
That was for me it's goin into a 92 si with a stripped interior. Just wonderin what will get me into the 14's no swap, turbo or NAAWWWS
Old Jun 20, 2003 | 04:22 PM
str8rcn's Avatar
Default Re: (hondasnmyblud)
All the bolt ons,I/H/E,pulleys and a head package from someone like JG,Gude or Portflow,and drag radials.Mid to low 14's no problem.
Old Jun 20, 2003 | 08:14 PM
jeff652's Avatar
Default Re: help on h23 (LudeyKrus)
The H22 Type S pistons work fine in an H23 VTEC engine. Static CR is about 11.5:1 with Type S pistons and the H23 stroke. The CR of the TYpe S pistons is 11.0:1 in the H22. The extra .5 comes from the increased stroke.
They clear the valves fine too . . .
Old Jun 20, 2003 | 08:16 PM
JBG's Ferio's Avatar
Default Re: help on h23 (jeff652)
I think you should search. This has been covered numerous times.
Old Jun 21, 2003 | 01:52 PM
Default Re: help on h23 (J B G)
I did search and the only thing I saw was someone who wanted to go in hte 13's and used NOS I just wanted to get in the 14's all motor H23 any opinions are appreciated. Would a lightened flywheel help my times?
Old Jun 21, 2003 | 02:22 PM
str8rcn's Avatar
Default Re: help on h23 (hondasnmyblud)
My car went consistant 14.2's with Gude head package,I/H/E,cam gears and pulleys on drag radials.
Old Jun 21, 2003 | 03:41 PM
LudeyKrus's Avatar
Default Re: help on h23 (str8rcn)
What's your redline when using the Gude's racing package?
Old Jun 21, 2003 | 07:14 PM
str8rcn's Avatar
They change the rev limiter to 86 or 8700.Way more than you need since it is designed to produce power in the stock range.
dk4ever
Oct 11, 2007 11:51 AM
dk4ever
Jan 1, 2007 09:09 AM
honda head
Apr 17, 2006 08:59 AM
92Periwinkle
Apr 1, 2004 01:56 PM
flamingaccord
Dec 2, 2003 03:26 PM
