radiator?
Old Jun 20, 2003 | 07:45 PM
Elkins911's Avatar
Default radiator?
just swapped from a 2.2 sohc to h22. i was wondering about the radiator... does my single cam radiator support my h22? im having a problem with over heating when im stopped. i changed out the thermostat last week, but the problem still comes up... just less frequently.
what do you guys think? possible radiator or water pump?
Old Jun 20, 2003 | 08:10 PM
PrecisionH23a's Avatar
Default Re: radiator? (Elkins911)
Are your fans kicking on when supposed to?
Old Jun 21, 2003 | 12:55 AM
viperguy's Avatar
Default Re: radiator? (GudeH23a)
Ha, Ha, the heat man got you too! My same problem still has not been solve. Today I took my car to the radiator shop where I bought my rad from and the guy did a thermo reading on it and he said everything seem normal . The fans kick in when it's suppose too (209 - 213 degree reading on the radiator using the thermo reader). It seems that might just have a bad sending guage sensor.
Old Jun 21, 2003 | 01:37 AM
Elkins911's Avatar
Default Re: radiator? (viperguy)
not to sure if the fans turn on. i guess i can test it tomorrow. the easiest way to test the fans is to just let the car idle right?
Old Jun 21, 2003 | 01:13 PM
Elkins911's Avatar
bump for the morning crew?
Old Jun 21, 2003 | 01:16 PM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">bump for the morning crew?</TD></TR></TABLE>not sure about you, but at this point i've already had a fulls day work at my day job, and am aobut to head to the night job
Old Jun 21, 2003 | 01:23 PM
Elkins911's Avatar
Default Re: radiator? (Boosted97Lude)
haha. i just woke up
Old Jun 21, 2003 | 01:29 PM
2kflamedlude's Avatar
I would say run a cooler thermostat
Old Jun 21, 2003 | 01:31 PM
Elkins911's Avatar
could it be my actual temp guage? im really not sure if the vtec model preludes have the same temp gauges or radiators at this point. please help.
Old Jun 21, 2003 | 02:20 PM
Elkins911's Avatar
ok... i got more info now.
i just let my car idle till it was at norm operating temp. the car was fine. so, i took it out for a couple hard drives for about 5 minutes. came back and let the car idle... it started heating up.
i popped the hood and noticed that the cooling fan never turns on. instead, the ac fans turns on (while the air conditioner is off). i noticed while the fan was on the car would over heat 2 bars, but as soon as the fan turned off the car cooled down again. WTF. anyone know what the problem here is.
this only happends at a stand still too. the car is fine when its driving. is the ac fan programmed to turn on if the cooling fan isnt working? if so, why does the car only over heat when the fan is on????
patroick67
Aug 1, 2012 06:56 PM
crazy_ham
Aug 4, 2008 12:37 PM
vxtirent08
Mar 20, 2008 10:36 AM
tkHBseries
Feb 19, 2005 06:48 PM
EGh22aEG
Jan 9, 2002 06:37 PM
