Foglight install.
Old Jun 15, 2003 | 08:51 PM
optikal_blitz's Avatar
Default Foglight install.
Hey i just bought a pair of foglights for my 92 Si! (words can not describe my excitement)
I'm curious;
1) It has ionized coating on it..is it removable?
2) The only instructions i found on it were from honda automotive parts.com
--problem is, i dont have that version of the console (i have a 92) so, where is the oem mounting point? anyone have a writeup?
3) Other than the mounting position of the switch- can i just follow the rest of the factory instructions or will things be different between my 92 and the example's 94?
thanks for the help guys.
edit:: and here is a picture of them.
Old Jun 15, 2003 | 08:54 PM
LudeyKrus's Avatar
haha, i was wanting to bid on those, but i already got a set! i think it's gonna be hard gettin the blue coating off...
Old Jun 15, 2003 | 08:58 PM
can not wait to get these things. maybe i shouldnt even bother trying to get it off...
Old Jun 15, 2003 | 09:14 PM
LudeyKrus's Avatar
Default Re: (NatakuBlitz)
imo, it looks good left blue; i'd wanna see the light it puts out, though
Old Jun 16, 2003 | 05:46 AM
Default Re: (LudeyKrus)
yeah i've heard good and bad about the out put on the oem fogs. Were they better in japan or both the same (except for yellow/clear lens)? Maybe the ionized blue covering will make it better?
Old Jun 16, 2003 | 02:29 PM
ttt
Old Jun 16, 2003 | 02:41 PM
4bidden's Avatar
Output on my OEM USDM fogs is awesome!
The mounting point for the 92-93s was in the drivers side tweeter cover. The tweeter cover is a very rare piece to find and the switch might be too. From the pics it looks like you have the 94+ switch, so youre just goin to have to rig it up somehow. Did you get the relay and harness and everything with them?
Old Jun 16, 2003 | 03:03 PM
i think i have the wiring harness.- didnt see any mention of a relay, so i might need to pick one of those up.
that brings me to another question:
when i took off my front bumper i noticed that i had an extra harness coming off my turn signals..is that for the fogs?
that would be extra convenient if it were.
i guess i'm on my own putting that switch on my dash, probably put it near my roof/cruise/dimmer cluster.
Old Jun 16, 2003 | 03:10 PM
Default Re: (4bidden)
btw; can i just buy a run of the mill relay? what should i be looking for when i go buy one?
Old Jun 16, 2003 | 03:19 PM
4bidden's Avatar
I'm not a wiring specialist so I wont answer that. I bought my fogs used from someone that bought them from Honda brand new and got EVERYTHING so install was plug and play for me. I will say that the plug you mentioned is for the fogs though.
Old Jun 16, 2003 | 03:27 PM
LudeyKrus's Avatar
go to RadioShack and get an automotive 4-pin relay and a plug and harness set for it too.
Old Jun 16, 2003 | 06:25 PM
how hard would the harnesses be to locate? apparently they aren't included.
Old Jun 16, 2003 | 07:08 PM
munscher's Avatar
What is the function of the harness and relay? Why can't the fogs just be wired up with a standard switch and call it a day?
Old Jun 17, 2003 | 03:17 AM
cantdrive55's Avatar
92-95 Civics have the exact same lens piece, and other honda models might as well, so if you'd like them clear again instead of having that funky looking blue on them, you can order those.
Old Jun 17, 2003 | 06:00 AM
LudeyKrus's Avatar
Default Re: (cantdrive55)
a switch can't usually handle the amperage the fog's will pull. The relay lets a low-amperage switch and wire control a much more powerful power source. Check out a set of fog's from Autozone and look at the harness they come with. you'll wire it up like this:
Switch side of relay:
pos.------switch-----------relay----------ground
Power side of relay:
pos.------fogs-------------relay-----------ground
on the switch side, you can pull the positive from the fuse box off a fuse that switches on w/ the lights, so you don't accidentally leave them on; but they can only come on w/ the headlights then. Check the package the relay came in; it should explain the pins.
http://cgi.ebay.com/ws/eBayISA...14934
Old Jun 17, 2003 | 09:04 AM
A4GY's Avatar
Default Re: Foglight install. (NatakuBlitz)
the look cool
Old Jun 17, 2003 | 11:01 AM
thanks a lot- i wanted them to be able to only come on when at least my parking lights are on..which also applies to when my lights are fully on. could i pull the positive lead from the parking light fuse?
Old Jun 17, 2003 | 11:44 AM
imported204's Avatar
those look good man
Old Jun 17, 2003 | 12:59 PM
munscher's Avatar
Default Re: (imported204)
LudeyKrus, thanks man that makes perfect sense to me.... i think i need to rewire my H1s that way as well, its switched right from the battery and the wires heat up really quick... this oughtta solve the problem.... beautiful.
Old Jun 17, 2003 | 01:12 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatakuBlitz &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot- i wanted them to be able to only come on when at least my parking lights are on..which also applies to when my lights are fully on. could i pull the positive lead from the parking light fuse? </TD></TR></TABLE>
yeah, you can.
Old Jun 17, 2003 | 02:32 PM
wordie, i really appreciate the help everyone. fogs should be in by the end of the week!
Old Jun 17, 2003 | 03:17 PM
R@mon's Avatar
all the wiring is already on your car. i put a set of them on my 93 so i know for sure.
the switch will just plug in to a plug that is taped off by the left tweeter wiring. you gota dig in there and youll find it.
the wiring for the relay is under or around the steering column, you just have to find it and use a relay that will fit it.i have one if you need it. just pay for shipping.
follow the directions on the hondaautomotiveparts. and you should be fine. the only thing you dont need is that little harness they sell. the relay will fit right into the one under the dash already. its really easy. pm with anymore questions....
Old Jun 17, 2003 | 03:38 PM
Default Re: (93h22a4)
alright, i just hope the lights arent cut to the wire, ill have to wait til i get them to figure out if i need the harness connections. Figure out how much that relay will cost and let me know..please? thanks!
Old Jun 21, 2003 | 11:11 PM
R@mon's Avatar
this is a picture of the relay. you should be looking for the brown plug under your dash. then the realy will just plug in...
disregard the blue wire with plug
Old Jun 21, 2003 | 11:55 PM
Daniel26's Avatar
Where can i get This fog-Lights? In wich Modell are this Lights build in? Can't find them in EPC.
Thanks a lot
