ecu threw me a code 65!!!!!!!!!!
Old Jun 18, 2003 | 01:00 PM
Param's Avatar
Default ecu threw me a code 65!!!!!!!!!!
Secondary Heated Oxygen Circuit
Circuit Malfunction
caused by: ???????
Open or short in Primary HO2S sensor heater circuit
ECM
so which o2 sensor is the primary one? the one that goes into the downpipe or the one for the cat??? because i've just recently installed new headers, but the check engline lights been on since before that.
Old Jun 18, 2003 | 01:01 PM
poison's Avatar
Default Re: ecu threw me a code 65!!!!!!!!!! (Param)
The Primary O2 sensor is located just after the collector on the header.
the Secondary O2 sensor is on the cat.
Old Jun 18, 2003 | 01:17 PM
Param's Avatar
so should i try tightening the bolt of the o2 sensor because there might be a leak or something?
Old Jun 18, 2003 | 01:41 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Param &raquo;</TD></TR><TR><TD CLASS="quote">Secondary Heated Oxygen Circuit
Circuit Malfunction
caused by: ???????
ECM
from what you posted, i would say to check the wiring for the o2 sensor.
Civic98KH
15
Dec 10, 2012 08:26 PM
draxxus07
Oct 13, 2005 05:41 PM
stehigs321
Jan 1, 2005 07:14 AM
ShittyGSR
Jul 17, 2004 05:59 PM
LS stretch
Mar 17, 2004 11:57 AM
