help
Old Jun 17, 2003 | 05:38 PM
chinhead1228's Avatar
Default help
I have a 97 lude with 105k. I been loosing a lot of oil however i dont have any leaks and theres no smoke coming out of my tail pipe (some times when i hit vtech). I took it to honda twice they dont know what the problem is, but i also think that they didnt take the engine apart yet. Does any body have an idea on what the problem might be. i also want to know when is the righ time to check the oil in the engine, is it when the engine is hot or cold.
PS i lose about a quart every 300 miles
Old Jun 17, 2003 | 05:59 PM
poison's Avatar
Default Re: help (chinhead1228)
Sounds like the piston rings are bad.
I would recommend you change the headgasket and get new piston rings.
Old Jun 17, 2003 | 06:23 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: help (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the piston rings are bad.
i concur
Old Jun 17, 2003 | 06:36 PM
Behan's Avatar
Default Re: help (Boosted97Lude)
1. check compression in cylinders. that will tell you in piston rings are bad. you should have an even compression through out cylinders
2. check for coolant in oil or vice versa. if either is present where they shouldn't be you have a bad headgasket.
3. check for oil on spark plugs. there are spark plug grommets that keep oil from reaching the plugs.
if you took it to honda, they should have checked the things listed above. there are probably some other things that you could check that i missed. so if you know of any other help him (and me) out.
Old Jun 17, 2003 | 06:43 PM
PrecisionH23a's Avatar
I am not a huge fan of the compression test. I favor the cylinder leakdown test, which is far more accurate. As stated before, your rings are probably going bad. Im curious, what weight oil are you using? When you do put your engine under load, it's regular to consume more oil especially in VTECH, as you stated earlier.
Old Jun 17, 2003 | 09:38 PM
Elkins911's Avatar
Default Re: help (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">I am not a huge fan of the compression test. I favor the cylinder leak down test, which is far more accurate. As stated before, your rings are probably going bad. Im curious, what weight oil are you using? When you do put your engine under load, it's regular to consume more oil especially in VTECH, as you stated earlier.</TD></TR></TABLE>
AMEN. god bless the leak down test....
benjoh
Oct 30, 2017 02:08 PM
92civichbor
10
Aug 5, 2008 11:09 AM
itrdave
May 1, 2007 10:44 AM
oryanh
Aug 19, 2003 04:32 AM
tominos
22
Feb 18, 2003 08:55 PM
