Transmission Help
Old Jun 15, 2003 | 01:00 PM
wutangben's Avatar
Default Transmission Help
Well I dropped my tranny the day before yesterday, yesterdat I decided to crack it open to see if i can find anything visually wrong with it. Well i took off the shift arm cover, took the rear idle fork shaft bolt (or whatever it's called out), removed the top two bolts that had the springs and steel ***** behind them. i removed the really two really long bolts, removed all of those 10mm bolts, and took the snap ring out of the groove in the bearing. i can pry the two housings apart, but it feels like the guts of it are still connected to both sides. i can only seperate the housing about a half an inch a part. anyone know why it doesn't want to come apart?
oh yeah, i took off one of the top seal things and found a bunch of synchro teeth and brass shavings... (oh boy).
Old Jun 15, 2003 | 01:43 PM
Prelude Vtec 23's Avatar
Default Re: Transmission Help (wutangben)
You all done, the only thing now that is holding it in is that there is a snap ring on the countershaft bearing, just remove it w/ a pair of snap ring pliers and it will come off no problem.
Old Jun 15, 2003 | 02:20 PM
wutangben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wutangben &raquo;</TD></TR><TR><TD CLASS="quote">and took the snap ring out of the groove in the bearing. </TD></TR></TABLE>
already did that... i've got the thing seperated about a half an inch. the snap ring isn't the problem.
Old Jun 15, 2003 | 08:19 PM
Honda318dx's Avatar
sounds like you just need to pull hard.. Oh, wait, did you take the sensor out, the one that activates your reverse lights???
jwbnavy
13
Nov 27, 2007 11:19 PM
Rustynuts
Aug 1, 2007 05:44 PM
SolTym
Oct 5, 2004 01:21 PM
gumbybum
Apr 11, 2004 03:37 PM
giooooo
Jul 20, 2002 10:29 AM
