Injecter size
Old Aug 15, 2003 | 10:38 AM
mattmw88's Avatar
Default Injecter size
What size injecters come stock on an h22a? What size should I get for my lude, 270 or 310? Also what should I get so that I can adjust them properly... nothing or a AFC, or a vtec controler. You can see my mods in my sig. Oh and I'm hoping to get new cams soon...Thanks for your help.
p.s. I'm also debating ecus right now, and I can't decide if I should go w/ a p72 or a p13 w/ some work to it. All help is appreciated
Old Aug 15, 2003 | 10:54 AM
prelittlelude's Avatar
Default Re: Injecter size (mattmw88)
i have a 94 h22a1 stock injector size is 345cc , if you have a fuel pum then you should use you ajustable FPR to adjust the fuel press becaseu aftermarkets usually have higher fuel press out of the box, then with your mods i would wait till you get you cams to get a vafc , then install your cams take it to a dyno and use the vafc. unless you go with a more advanced setup i wouldn't get a ecu liek hondata or aem ems.
edit: i don't know alot about the vafc but i think it should be good for tuning esp if you get cams i think the vafc lets you adjust your vtec cross over
Old Aug 15, 2003 | 11:00 AM
mattmw88's Avatar
Default Re: Injecter size (prelittlelude)
WOW! 345? Are you completely sure? How do you know? Thanks
Old Aug 15, 2003 | 11:08 AM
do a search
1992-96 Prelude non-vtec Peak and hold 240cc
1992-96 Prelude VTEC Peak and hold 345cc
1997-up Prelude VTEC Saturated 290cc
Old Aug 15, 2003 | 06:53 PM
H22Si's Avatar
I had my factory '94 H22 injectors flowtested by RC. After cleaning the flowrates ranged from 340-345cc
a1320addict
Nov 22, 2004 07:56 PM
GoodFella
Nov 6, 2002 12:08 PM
C-Murdock
Sep 17, 2002 06:05 PM
rb26dett
Apr 9, 2002 05:57 PM
