erratic idle problem
Old Aug 13, 2003 | 01:48 PM
killa_lude's Avatar
Default erratic idle problem
my car idles crazy, it goes up to 2k and then drops down to .5k, it does this everytime i pop the car into neutral. what should i check??
Old Aug 13, 2003 | 02:03 PM
P.O.H.'s Avatar
Default Re: erratic idle problem (killa_lude)
it might be your Fast Idle Thermo Valve or your Idle screw.... here's a test...
when your lude is idling weird... take off your intake tube and in side the trottle body on the bottom left (closer to the firewall) you should see a port, cover this port with your finger (while it's at idle), you will feel suction but not to the point were you'll lose a finger, hehe. Once you put you finger over this port.... if your idle settles out, then it's your FITV... but if it doesn't, it might be your idle screw. To lower your idle, screw the idle screw clockwise...... in turn, to increase your idle, turn the screw counter clockwise ...if your idle is boucing, more than likely your idle is to high for some reason.... if it's the idle screw then turn it clock wise.
Hope this helps.
Ceasar
Preludes Of Houston
Old Aug 13, 2003 | 06:23 PM
killa_lude's Avatar
Default Re: erratic idle problem (P.O.H.)
thanks man i will try both. i recently took my throttle body off to clean it..so the test should be easy.
Old Aug 14, 2003 | 08:24 PM
killa_lude's Avatar
where's the fast idle thermo valve?
Old Aug 15, 2003 | 05:53 AM
P.O.H.'s Avatar
well it depends... what motor do you have F22, H23, or H22?
If it's the F22 it's located on the top right side (if your standing in front of your lude) of the intake manifold.... if you have the H23 or H22 it should be located under the trottle body. F22 position Part# 9 http://www.hondaautomotivepart...81%29 . For the Si & VTEC is Part #13
http://www.hondaautomotivepart...82%29 . Let me know if this helps.
Ceasar
Preludes Of Houston
Old Aug 15, 2003 | 09:21 AM
killa_lude's Avatar
yeah i found it (h22), what if i just put a plate over the 3 ports??
Old Aug 15, 2003 | 10:08 AM
del_parker's Avatar
yeah, blocking off the holes will work. the fast idle is easy to fix though, just take it apart, clean it, and put it back together. i have a plate blocking off my EACV.
Old Aug 15, 2003 | 10:26 AM
93 VTEC's Avatar
Default Re: erratic idle problem (del_parker)
I had the same problem with mine, but not as bad. It would surge from 1200-2000RPM. I tried the easiest fix first and adjusted the idle screw. Now it idles fine. A little low, but im gonna bring it back up.
Old Aug 15, 2003 | 10:35 AM
silver97prelude's Avatar
mine does the same thing, ive never heard of the idle screw or fitv though
mine does it when the ac is on and im at a complete stop, it does it in neutral and gear. is this the same thing?
Old Aug 15, 2003 | 12:33 PM
killa_lude's Avatar
Default Re: erratic idle problem (silver97prelude)
well i took my ac out, but it all started when i did the throttle body coolent bypass. the fast idle thermo valve (bottom of TB) is suppose to stay open when the engine is cold and slowly close when the engine gets hot. well if you have no coolent running throught the TB the valve thinks that the engine is cold, so it stays open...when the engine is actually hot. i experienced lost of power and a erratic idle. i put a plate over the ports and took the valve housing off, and problem solved.
Old Aug 15, 2003 | 12:54 PM
P.O.H.'s Avatar
killa_lude...... glad you were able to fix the prob.... don't know if I helped any... but glad you fixed it.
Ceasar
Old Aug 16, 2003 | 08:33 AM
killa_lude's Avatar
Default Re: (P.O.H.)
yeah man you helped me alot, i've been trying to figure what was going on for the past 2 months, i really appreciate the info....
james007
Apr 30, 2010 04:26 PM
DC2*Integra
Sep 20, 2005 12:51 PM
350z-tech
Nov 10, 2001 10:46 PM
