Idle Problem.. Please Help
Old Mar 29, 2004 | 01:30 PM
H22A1CivicEG's Avatar
Default Idle Problem.. Please Help
Hey, what's up to everyone.. I'm new to this site. I have an h22a1 in an EG and im having problems with my idle. It likes to sit at 1500 and rev up and down like every half second. Its revving like maybe 400 rpm.. just installed JUN cams and head internals.. I thought that maybe the problem was the Idle Controll Valve from what ive been reading on this site but I checked it and its firm in there.. any help on what he problem may be? Much appreciated
Old Mar 29, 2004 | 01:45 PM
Speedra500's Avatar
Default Re: Idle Problem.. Please Help (H22A1CivicEG)
There is a cold idle valve and a fast idle valve i believe, are you running the coolant hoses through your TB and IAC?
Old Mar 29, 2004 | 05:35 PM
Default Re: Idle Problem.. Please Help (Speedra500)
Yea, all the coolant lines are running..
Old Mar 29, 2004 | 07:04 PM
stubk20's Avatar
Do you have a lightened flywheel? my idle is a little off to ever since I put it in.
Old Mar 29, 2004 | 07:06 PM
93ludeSi's Avatar
Default Re: Idle Problem.. Please Help (stub92111)
Whats the duration on these cams??? Are you using factory ecu ect? You might find that with the aftermarket cams you are going to have to increase the factory idle with a hondata or somthing
Old Mar 29, 2004 | 08:58 PM
Default Re: Idle Problem.. Please Help (93ludeSi)
i should have been more clear.. i can get it to idle if i rip on the gas and the engine slows down on its own... but when i lightly touch the gas the cams will want to stay at 1500 and rev like 400 rpms every half-second..... and nope, stock flywhell, JUN soon though.... H22A
PROFILE PART# NOTE
#1 #2 #3
ANGLE LIFT ANGLE LIFT ANGLE LIFT
INT 62 (248) 9.2 INT 74 (296) 12.2 INT 60 (240) 7.7 1004M-H011 Sepecial valve spring required.
EXT 61 (244) 7.7 EXT 74 (296) 11.9 EXT 63 (252) 9.0 1004M-H111
Old Mar 30, 2004 | 02:06 PM
Help is majorly needed, ive exhausted all the options that i know of..
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
hybridracer504
12
Feb 8, 2005 05:25 PM
SLOAZZ95
Nov 5, 2003 04:42 PM
diLUDEd
Aug 22, 2002 10:08 PM
