MSD Digital SCI +
Old Mar 30, 2004 | 07:03 PM
TypeRKoncepts's Avatar
Default MSD Digital SCI +
I bought the MSD Digital SCI+ ignition and Blaster SS coil for my 1994 JDM h22a. i was just wondering if i can use the external coil. Pardon my ignorance but can it be done? does anyone else have any other msd ignition control units and the blaster ss external coil on their obd/jdm preludes?
Old Mar 30, 2004 | 07:23 PM
98 blacksh's Avatar
Default Re: MSD Digital SCI + (TypeRKoncepts)
i had the same setup on my 93 accord?
Old Mar 30, 2004 | 07:24 PM
so you used the SS coil no problem? with the digital sci + (or regular sci)
Old Mar 30, 2004 | 08:25 PM
NoLipRacen's Avatar
Default Re: (TypeRKoncepts)
i believe jdm h22s use an internal coil so you would need to get a usdm distributor to run that ignition
Old Mar 30, 2004 | 08:33 PM
they do.. so i can't use the ignition without the external coil?
Old Mar 30, 2004 | 08:57 PM
Hawkze_2.3's Avatar
You could wire up the ignition, but you couldn't use the MSD coil without converting..
Old Mar 31, 2004 | 10:07 AM
i still have my accord external distributor on my f22... do you guys suggest converting and using hte SS coil or is it fine the way it is, just hooking up the ignition box?
Old Mar 31, 2004 | 08:34 PM
ty_racer's Avatar
msd makes an external coil adapter kit and you can even use your oem cap you just cut a hole in the spot for the where the external coil plug would go and they give you a little adapter thing so you don't have to do much wiring it really cool. im not sure where you can get it but if you get ahold of MSD im sure they can set you up
Old Mar 31, 2004 | 09:42 PM
skrewdlude's Avatar
Default Re: (ty_racer)
This is what I use. I got it from summit racing http://www.summitracing.com It was about 8 bux. You can also use the cap from a '90 accord. MSD makes a cap for the accord. I use the '90 accord OEM cap and use the power tower converter. You just drill a hole, and screw the power tower thru the hole. You have to make sure it has contact with the metal rod that pass to the coil. It is really simple.
Josh
Hawkze_2.3's Avatar
Performance-wise the MSD coil won't make much difference, but it will provide a more powerfull spark than the stock coil.....It's lighter too, and you can mount it most anywhere...
_oemek_
Aug 16, 2004 04:16 PM
integrasi
Mar 5, 2003 12:28 AM
Ray
Dec 15, 2001 10:17 PM
Duck Sauce
Nov 16, 2001 08:19 PM
