ATTS Fluid..
Old Mar 29, 2004 | 06:38 AM
UmaMamoo's Avatar
Default ATTS Fluid..
According to the owner's manual of the 5th gen Prelude, the 90,000 mile service requires (among other thingys) changing the ATTS Fluid. However, a call to our friendly Honda dealership reveals no such thing as "ATTS Fluid".. what gives?
Upon inspection, the unit that holds the ATTS fluid had the words "MCU Oil" written on it.. We drained it into an empty container just in case we had to re-use it, and it basically smelled just like regular manual tranny fluid, so that's what we replaced it with.
Anyone have any insight into this? Thanx in advance!!
Old Mar 29, 2004 | 07:02 AM
Daemione's Avatar
Default Re: ATTS Fluid.. (UmaMamoo)
It uses automatic tranny fluid.
Old Mar 29, 2004 | 08:31 AM
jji106's Avatar
Default Re: ATTS Fluid.. (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">It uses automatic tranny fluid.</TD></TR></TABLE>
What he said!
I thought about using Red Line ATF High Temp, but I didn't think it was worth it and I'm sure the ATTS is pretty finnicky as to what fluid it wants!
Just use Honda ATF!!
Old Mar 29, 2004 | 09:25 AM
UmaMamoo's Avatar
Default Re: ATTS Fluid.. (jji106)
Hmm.. so wait, we've already changed it to Honda MTF (manual tranny fluid).. the same stuff we put in the tranny.. Will having the MTF instead of the ATF cause a problema?
Old Mar 29, 2004 | 10:26 AM
98 blacksh's Avatar
my guess is that it might because they are different not sure though
Old Mar 29, 2004 | 11:03 AM
SH LUDE's Avatar
Old Mar 29, 2004 | 03:01 PM
OTT's Avatar
OTT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UmaMamoo &raquo;</TD></TR><TR><TD CLASS="quote">Will having the MTF instead of the ATF cause a problema?</TD></TR></TABLE>
It seems like this guy put the wrong fluid in the wrong place, result = his motor pulls like crazy!
https://honda-tech.com/zerothread?id=811943
Quote of the week
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UmaMamoo &raquo;</TD></TR><TR><TD CLASS="quote">..and it basically smelled just like regular manual tranny fluid, so that's what we replaced it with. </TD></TR></TABLE>
Priceless
Old Mar 30, 2004 | 06:35 AM
UmaMamoo's Avatar
Default Re: (OTT)
The Honda dealer I innitially spoke with said to change both the tranny as well as the ATTS with Honda MTF, which we've already done.
So I should drain the ATTS unit again and change it to Honda ATF then, correct?
Modified by UmaMamoo at 10:58 AM 3/30/2004
Old Mar 30, 2004 | 10:26 AM
OTT's Avatar
OTT
Yup! unless you wanna keeps riding curbs and takeing loans to pay for tires! then when your done drive to that Honda Dealer & give him your compliments !
Old Mar 30, 2004 | 11:45 AM
UmaMamoo's Avatar
Default Re: (OTT)
Capiche..
Although on a side note, I haven't experienced the problems you, nor the person in the other thread mentioned.. in fact, haven't had any problems at all since the service. But then again, why wait for the problems to start.
Appreciate the info!
redDAinteg
Nov 20, 2008 10:46 PM
singher01
Jul 25, 2008 10:19 AM
mysicivic1991
Apr 16, 2007 09:53 AM
kornerk12
Nov 18, 2005 05:37 AM
inzaneN1
Feb 7, 2004 03:57 AM
