VTEC controler
Old Mar 31, 2004 | 05:11 AM
RJH6's Avatar
Default VTEC controler
I just got a vtec controler and i just wanted to know were i should put it?
Old Mar 31, 2004 | 05:26 AM
killa_lude's Avatar
Default Re: VTEC controler (RJH6)
what kind of car do you have?
Old Mar 31, 2004 | 06:48 AM
mattmw88's Avatar
Default Re: VTEC controler (killa_lude)
any one have any creative ideas for 4th gen preludes? I 've seen some in the ashtray, but use mine to hold all my change. I really don't want to drill holes into my beautiful dash
Old Mar 31, 2004 | 07:20 AM
speedracer9k's Avatar
i put mine on my steering wheel column so all i have to do is glance down to read it and it doesn't block my gauge cluster
Old Mar 31, 2004 | 07:28 AM
Behan's Avatar
Default Re: (speedracer9k)
i put mine on the passenger side of the dash, next to the speaker cover. its secured with 3M double sided sticky pads. i rarely use mine to monitor functions so i don't need it in my line of sight. i use the stock tach to shift. if i shift at redline on the stock tach in reality i'm shifting at 7k to 7.2k (which is where my power peaks) via the vafc.
Old Mar 31, 2004 | 07:52 AM
94vtecmn's Avatar
Default Re: (Behan)
Same exact spot I have mine.
Old Mar 31, 2004 | 09:12 AM
Behan's Avatar
Default Re: (Behan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Behan &raquo;</TD></TR><TR><TD CLASS="quote">i put mine on the passenger side of the dash, next to the speaker cover. its secured with 3M double sided sticky pads. i rarely use mine to monitor functions so i don't need it in my line of sight. i use the stock tach to shift. if i shift at redline on the stock tach in reality i'm shifting at 7k to 7.2k (which is where my power peaks) via the vafc. </TD></TR></TABLE>
this location also makes it very easy to hide/route the wires. right behind the speaker cover, tucked behind the carpet and right to the ecu.
Old Mar 31, 2004 | 09:34 AM
killa_lude's Avatar
Default Re: (Behan)
Old Mar 31, 2004 | 10:56 AM
OTT's Avatar
OTT
Did you have to chop some plastic to fit that?
Old Mar 31, 2004 | 11:25 AM
killa_lude's Avatar
Default Re: (OTT)
yeah almost an inch.
Old Mar 31, 2004 | 11:29 AM
94vtecmn's Avatar
Default Re: (killa_lude)
Nice toes!
Old Mar 31, 2004 | 07:40 PM
killa_lude's Avatar
Default Re: (94vtecmn)
my gf's.
Old Apr 1, 2004 | 08:56 AM
@ries's Avatar
Old Apr 1, 2004 | 09:03 AM
killa_lude's Avatar
Default Re: VTEC controler (emoBB1)
where did you get that steering wheel? i want it, how much did it cost?
Hatchman98
Jun 7, 2007 01:45 PM
b16a4
Jan 21, 2007 08:33 AM
5thGenBen
Aug 20, 2004 06:53 AM
Doug684
13
Mar 13, 2004 05:13 PM
Spaceballsthelunchbox
Apr 1, 2002 09:02 PM
