Intake Pipe
Old Apr 4, 2004 | 01:31 PM
vinuneuro's Avatar
Default Intake Pipe
Has anyone tried the Ractive intakes of ebay. A guy is selling just the pipe. I was thinking of getting that and then getting one of those Apexi filters which are suppose to be good. What do you think? How good are those pipes, will they be a lot worse than say AEM?
Old Apr 4, 2004 | 02:06 PM
hOndafienD 04's Avatar
a pipe is a pipe....the only part that matters is the filter...i would suggest a k & n filter....is the pipe short ram or cold air? that will make a difference....car air will have slower throttle response...but it will be bettercuz of the colder air brought into the engine...
Old Apr 4, 2004 | 02:17 PM
Kal's Avatar
Kal
Default Re: (hOndafienD 04)
apex filters flow better
Old Apr 4, 2004 | 02:51 PM
vinuneuro's Avatar
any other opinions?
Old Apr 4, 2004 | 09:45 PM
Hawkze_2.3's Avatar
Default Re: (vinuneuro)
Yessir, a pipe is a pipe...unless it's plastic or it won't fit....
Old Apr 5, 2004 | 07:44 PM
vinuneuro's Avatar
Default Re: (Hawkze_56)
do the AEM dissipate heat better than the other ones?
Old Apr 5, 2004 | 08:01 PM
Daboi630's Avatar
look into this....
http://mkiv.com/techarticles/filters_test/2/
Old Apr 5, 2004 | 08:08 PM
vinuneuro's Avatar
Default Re: (Daboi630)
that was a good article, but i am more interested in the pipe. Among the leading intake manufaturers, which intakes sound good? Also, how great is the heat dissapation ability between ebay pipes and the usual ones? Also, if i were to get an ebay pipe would you suggest getting that Ractive V2 style pipe or a regular short ram pipe?
Old Apr 5, 2004 | 08:28 PM
Daboi630's Avatar
sound? sounds the same to me
if you are worried about heat i believe you could coat it. but i wouldnt be too worried about it.
and last, i say a pipe is a pipe. don't worry about it so much.
Old Apr 5, 2004 | 08:40 PM
prelude1897's Avatar
You can just paint the pipe with heat resistant paint which you can buy from AutoZone or some other auto part store. I did that with mine, and it worked just fine
turkdog
Aug 12, 2005 12:44 AM
darknessplayboy
May 4, 2005 05:14 PM
boostincoupe
Jan 28, 2005 06:20 PM
mugenracer
Mar 4, 2002 05:17 PM
